what compression are the high rollers running?
Old Oct 17, 2011 | 08:16 AM
MR.johnson's Avatar
Default what compression are the high rollers running?
Getting custom pistons over winter. Seeing what some people are running. Will be ported head, tuner2/itr cams, gsr stroke, 84.5mm and hta3786.
Old Oct 17, 2011 | 08:53 AM
TheShodan's Avatar
Moderator
Default Re: what compression are the high rollers running?
That's subject to use of the car. Considering you're using an expensive item like the FP3786, I'd say anything 9.0:1 and over are pretty good for a honda with such a large turbo.
Guess I'm trying to figure out what you're really asking
Old Oct 17, 2011 | 10:31 AM
zatch18's Avatar
I am running 11.0:1 JE pistons with a GT35 setup on a B16. Stage2 tuner cams, supertech valvetrain.
Old Oct 17, 2011 | 11:06 AM
digital sol's Avatar
what fuel?
power made?
daily driver or track car?
Old Oct 17, 2011 | 02:35 PM
MR.johnson's Avatar
It's a strait line street car. Track a few times a year...
Old Oct 17, 2011 | 04:26 PM
sweetfwdthunder's Avatar
10.9:1 85mm gsr, ported b16 head, ctr cams, s366XL
Old Oct 17, 2011 | 07:07 PM
MR.johnson's Avatar
numbers?
Old Oct 18, 2011 | 04:55 AM
non-VTEC's Avatar
i would shoot for 9.5:1
Old Oct 18, 2011 | 10:33 AM
Muckman's Avatar
Moderator in Chief
Everyone should list fuel and power you are making, not just compression.
Old Oct 18, 2011 | 07:11 PM
MR.johnson's Avatar
e85 wanting to make 800+
Old Oct 18, 2011 | 07:19 PM
GEN2 LS's Avatar
Loved
stock bore/stroke b16, 11:9:1 compression built head itr cams precision 6031, goautoworks ramhorn 9psi 337whp 232 trq, tuned on E85
Old Oct 21, 2011 | 05:43 AM
MR.johnson's Avatar
Anyone else?
Old Oct 21, 2011 | 10:07 AM
Muckman's Avatar
Moderator in Chief
Lets keep this thread going. Who else is making big power 500+ with high comp on E85?
Im rebuilding my engine with 11.5 compression this winter. Shooting for 600 on E85.
Old Oct 21, 2011 | 10:50 AM
shawty22's Avatar
I cant wait to see this next year Mr. Johnson.
Old Oct 21, 2011 | 11:52 AM
Is this going to be street driven or track only?
Is 11:5 considered to still be rather high even with e85 as a fuel source for a boosted application making that kind of power?
Ive seen alot of 10:1, 10:5, or 11:1 set-ups but ive never seen any build using higher than 11:1 comp w/e85 or pump gas that is driven other than pure track cars.
Just curious for my own build....ive got 11:5 pistons laying around ATM but thought they would be "too high" comp for a car seeing alot of street miles...but the higher comp would be nice for guys running larger t4 turbo's and wanting that quicker spool or engine response while off boost...
Thoughts?
Old Oct 21, 2011 | 03:18 PM
non-VTEC's Avatar
i'll stick to my sub 9.5:1cr....i can pump 91 into it and not worry about it...or run 94oct pump and run high enough boost that will be plenty powerful enough.
Old Oct 23, 2011 | 10:58 AM
MR.johnson's Avatar
so 9.5 and call it a day on e85?
Old Oct 23, 2011 | 11:50 AM
Turbo-LS's Avatar
GSR w/ls crank eagles/srp's - 9.6:1 comp
sc60e turbo, spa cast top mount
CTR cams, supertech valve, omni springs, stock port head
victor IM, STR 70mm TB
406whp on 93 pump
car runs great out of boost, very snappy throttle responce, throttle responce will pick up from a TB and good ignition system over a few tenths in compression
Old Oct 23, 2011 | 04:28 PM
Muckman's Avatar
Moderator in Chief
digital sol - its a street car that is not daily driven. Pretty much only driven to the dyno and track. Does that make it a race car? lol
Mr. johnson - you could easily do 9.5 on pump gasoline. Way higher on E85.
Old Oct 23, 2011 | 04:58 PM
93supercoupe's Avatar
last year we did 9to1 at 460whp and 93 oct.
This year will be 10to1 and 500+ on 93 oct. and 750+ on race fuel
Old Oct 23, 2011 | 05:55 PM
Muckman's Avatar
Moderator in Chief
What octane is your race fuel?
CivicGSRsi
10
Dec 26, 2006 12:03 PM
rug
Sep 11, 2006 10:38 PM
91 Civic B16
Oct 2, 2005 11:07 AM
Ti3d in
Jul 11, 2004 02:45 PM
bOOsTiNSoHcVtEc
Mar 31, 2004 10:06 AM
