What Comp. with n2o???????
Old May 4, 2003 | 06:21 PM
bottlefedb18c1's Avatar
Default What Comp. with n2o???????
How high comp. should i go with n2o on a street car on a b18c1??
I have the NX dual stage wet kit so i can go from a 35 to a 300 shot
and it is going to have a build head and rods along with the JE pistons
i tried this in the drag racing forum but i only got one persons opp. on it
Old May 4, 2003 | 07:48 PM
psi420's Avatar
I say go as high as you want.
Be considerate when you make a decision, dont go 13:1 with a 200 shot.
11.8:1 w/ a 100 shot would haul some serious ***!
Good thing to think about is Progressive controller, and aftermarket ignition.
Timing controls while on the squeeze would help too.
Pull back some timing, and run colder plugs.
Maybe think about upgrading that wet kit, to a direct port for added safety.
Wet kits do puddle, and can explode your manifold.
Old May 4, 2003 | 08:05 PM
i was considering 11:1 with a 50 out of the hole and a 75-100 after that
Old May 4, 2003 | 08:20 PM
psi420's Avatar
Sounds perfect!
Old May 4, 2003 | 08:24 PM
Default Re: (psi420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds perfect!</TD></TR></TABLE>
or is that too much?
Old May 4, 2003 | 10:18 PM
Default Re: (bottlefedb18c1)
but that extra 75-100 is going to be on top of the 50 shot
Old May 4, 2003 | 10:27 PM
psi420's Avatar
so your talking 150 overall.....you better be very well tuned, and I highly suggest progressive control.
Old May 4, 2003 | 10:51 PM
i was also thinking about a few deg retard on the igntion and a few cooler on the plugs and hondata with there n2o controlers
d16civic111
17
Apr 12, 2006 12:01 PM
175Shot4Door
Apr 4, 2006 06:53 PM
soriano4521
Aug 30, 2005 12:27 PM
Mattmob
Dec 20, 2004 05:54 PM
fastludeh22
Apr 17, 2003 07:59 AM
