cp piston owners
Old Jul 10, 2004 | 05:44 AM
EKB18BPR3's Avatar
Default cp piston owners
did ur rings including both compression rings, oil rings and the squigly thingy overlapped when u first got them with ur pistons? all mine do and i think i got the wrong rings with my pistons. the size pistons i got is standard and the rings that came with it has serial # CPN-3209 and the code stamped on the ring says N50. thanx
Old Jul 10, 2004 | 06:21 AM
B18C1CYA's Avatar
Default Re: cp piston owners (98B00STED)
you should im earl , he is the cp man
Old Jul 10, 2004 | 07:10 AM
Rod.'s Avatar
Default Re: cp piston owners (B18C1CYA)
earl
Old Jul 10, 2004 | 07:17 AM
EKB18BPR3's Avatar
Default Re: cp piston owners (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">earl</TD></TR></TABLE>
ok ill do
Old Jul 10, 2004 | 08:30 AM
earl's Avatar
Those rings are for an 81.5mm bore. What is the part number of the pistons? If you have a stock bore, you got the wrong rings and they must be exchanged. Do not try to cut them to size. Where did you buy them?
Old Jul 10, 2004 | 04:17 PM
EKB18BPR3's Avatar
Default Re: cp piston owners (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Those rings are for an 81.5mm bore. What is the part number of the pistons? If you have a stock bore, you got the wrong rings and they must be exchanged. Do not try to cut them to size. Where did you buy them?</TD></TR></TABLE>
i bought them from Extremepowerouter on ebay but he sells them on HT.com too. and i just emailed him with what u just said. the pistons are the correct size because i used it to slide the rings down the cylinder to measure the gap.
marvinmark21
Jan 14, 2008 09:36 AM
garyc17
Jun 12, 2007 02:26 AM
K-Spec
Nov 10, 2005 04:13 AM
HondaGuy02
May 22, 2005 01:47 PM
Trailz-EX
Dec 1, 2004 07:50 PM
