What causes the end of a rotor to melt?
Old Jun 3, 2006 | 05:04 PM
XES's Avatar
XES
Default What causes the end of a rotor to melt?
I have been trying to troubleshoot problems with the ignition system (i believe) on my vehicle.
I was using a MSD digital 6plus, HVC coil, MSD wires and NGK v-power 8s, but have since removed the msd box and coil and put a stock internal coil distributer in. The car is sputtering very bad once i hit 5k-6k rpm (and was with the msd also).
In addition I noticed that the rotors were always getting burned bad on the left edge even to the point where plastic was melting around them (i will upload pics later). This was happening within the first 50-100kms. What would cause this? Should it only happen when i had the msd coil and box in?
Old Jun 3, 2006 | 05:11 PM
PrecisionH23a's Avatar
Default Re: What causes the end of a rotor to melt? (XES)
Mine was doing that too a while ago... once I swapped dizzy's the problem went away. I had really bad break-up under high load and around 4k rpms. I'm guessing the ignitor was the guilty party.
Old Jun 3, 2006 | 06:43 PM
XES's Avatar
XES
Default Re: What causes the end of a rotor to melt? (PrecisionH23a)
Here is the pic:
sanman000719
Jan 8, 2009 11:17 AM
darkstar1440
Jul 27, 2006 07:54 AM
Undercover_Skank
Apr 11, 2005 08:51 AM
K-Spec
Jan 8, 2005 03:48 PM
_oemek_
Aug 16, 2004 04:16 PM
