what can i do to make it last?
Old Jul 1, 2008 | 01:56 PM
lickety_britches's Avatar
Default what can i do to make it last?
im getting ready to go turbo but i want it to last (duh) i wanna make like at least 325whp. so what should i do to my engine now for it to be able to handle the power? i have a GSR with itr cams, aem CAI, DC header, crower valve springs. but a stock block : / so what should i do to prepare? pistons and such?
Old Jul 1, 2008 | 02:20 PM
hotrod99's Avatar
Default Re: what can i do to make it last? (lickety_britches)
aftermarket pistons and rods help,but most of all it needs a good tune...you could do 325hp on stock block just make sure you have a tuner that knows what he's doing
Old Jul 1, 2008 | 07:45 PM
blinx9900's Avatar
a few things you can do, might be obvious to some but here we go:
-check your oil often, change it if it looks bad, dont rely on mileage
-get a good PCV setup going
-keep an eye on your water temps, get an oil temp gauge if you can
-dont use cheap gasoline
the rest is in the tune
Old Jul 1, 2008 | 09:47 PM
count me out's Avatar
* B A N N E D *
Default Re: what can i do to make it last? (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">a few things you can do, might be obvious to some but here we go:
the rest is in the tune </TD></TR></TABLE>
black oil means its working, not that its necessarily bad.
anyway, op has lots of SEARCHING to do.
Old Jul 2, 2008 | 12:21 AM
blinx9900's Avatar
Default Re: what can i do to make it last? (count me out)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by count me out &raquo;</TD></TR><TR><TD CLASS="quote">
anyway, op has lots of SEARCHING to do.</TD></TR></TABLE>
thats debateable, my oil was always fresh and clean when i was NA even after 3000mils of hard driving, the inside of the motor was so clean you could eat off it. however on turbo cars i was more referring to the consistency, if it looks watery change it...
h23vtecpowered
Nov 15, 2007 07:58 PM
vtec4max
May 27, 2007 08:53 PM
NA_H22_Ej
11
Mar 26, 2007 06:32 AM
JdmEkb18
Mar 26, 2005 08:41 AM
B18C1CYA
May 3, 2004 06:12 PM
