What cams to use for a boosted setup :::searched:::
Old Feb 9, 2007 | 04:00 PM
92LSVTEC's Avatar
Default What cams to use for a boosted setup :::searched:::
doing a little investigation, heres my set up so far......
ERL Sleeved Block, JE 9:1, turbo tuff rods, ferrea valves (still debating oversized or not) springs, retainers, F-R Top Mount, T4/T67 HO BB, 26-30psi, 1000 cc injectors, victor X intake mani, (hopefully will have the head ported before the final assembly) looking to make between 650-700 whp. let me know what you think. if that number is realistic any idea what cams, (if any) i should run?
Old Feb 9, 2007 | 04:11 PM
A.E Motoring's Avatar
Default Re: What cams to use for a boosted setup :::searched::: (92LSVTEC)
type r or gsr cams
Old Feb 9, 2007 | 06:20 PM
Blown90hatcH's Avatar
CTR/ITR
Old Feb 9, 2007 | 06:42 PM
cuin9sec
Guest
Posts: n/a
Default Re: What cams to use for a boosted setup :::searched::: (Dual Cam Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing &raquo;</TD></TR><TR><TD CLASS="quote">type r or gsr cams</TD></TR></TABLE>
gsr if you cant afford itr/ctr.
then one more option is Mazworx new cams that he is running.
https://honda-tech.com/zerothread?id=1567252
Old Feb 9, 2007 | 06:59 PM
92LSVTEC's Avatar
Default Re: What cams to use for a boosted setup :::searched::: (Blown90hatcH)
.81 a/r, 4 inch downpipe... probaly going to run open d/p for time being... think the power goals are accurate? or am i dreaming?
Modified by 92LSVTEC at 1:08 AM 2/10/2007
Old Feb 9, 2007 | 11:59 PM
cuin9sec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">.81 a/r, 4 inch downpipe... probaly going to run open d/p for time being... think the power goals are accurate? or am i dreaming?
Modified by 92LSVTEC at 1:08 AM 2/10/2007</TD></TR></TABLE>
power goals are a little high BUT have been achieved. i know a friend thats hit 730whp on the t3/t67 h.o. and thats was bad ***!
good luck to you
Old Feb 10, 2007 | 10:03 AM
Top Ramen's Avatar
Default Re: What cams to use for a boosted setup :::searched::: (cuin9sec)
Go wtih ITR cams. Once you get above moderate boost levels, they out-perform the gsr cams.
Best of luck with your project.
93gsr4dr
Mar 3, 2012 06:09 PM
98GSR-Turbo
Nov 8, 2007 10:49 AM
b18c-1
Jun 14, 2006 12:55 PM
EJ8 GSR-T
Feb 20, 2006 09:42 PM
jdmek910
Nov 21, 2004 05:41 PM
