what cams and revlimit for built ls vtec
Old Jan 3, 2010 | 01:01 PM
TeggieeTuner's Avatar
Default what cams and revlimit for built ls vtec
i have a built ls vtec wit hthe following:
arias 9:1 Pistons
eagle Rods
acl bearings(all bearings)
gsr girdle on ls block
arp head studs
gsr head (stock)
i also have a b16 head(stock)
(dont know what head to use)
precision 880cc injectors
walbro fuel pump
shooting for mid 400whp
i want cams the have the meanass lopey sound like the toda vtec killers
but i know there not good for boosted engines but is that true even if its tuned for them??
and what should i set my rev limit at?
Old Jan 3, 2010 | 01:12 PM
cjordan's Avatar
Default Re: what cams and revlimit for built ls vtec
I run VTEC killers in my car and it did very well, we made good power with little boost. The only downside is I do not recommend trying to drive them on the street, I hate it when i catch stop lights!!! But dont buy a cam for the " sound " if your only shooting for 400whp I would run a type r cam or skunk2 pro2 cam.
Old Jan 3, 2010 | 01:50 PM
GEN2 LS's Avatar
Loved
some ITR cams will work perfect, if your set on some aftermarket cams, skunk2 pro1's make some nice midrange.
Old Jan 3, 2010 | 02:02 PM
i just love the intimidating sound of the mean *** lope....
its sounds sick...
but i love vtec when it hits with boost it feels like a whole other monster...
Old Jan 4, 2010 | 11:06 AM
miggiej8's Avatar
Vtec and boost is the best feelin in my opinion
I
Old Jan 4, 2010 | 04:03 PM
I
agreed.
Old Jan 12, 2010 | 11:43 AM
sh!ft's Avatar
Who the fack changed my title?!
i have a build similar to this going togeather. but more aftermarket parts and more precise decision making is going into this build. has anyone used a ctr intake and an itr exhaust??
Old Jan 12, 2010 | 11:48 AM
Turbo-LS's Avatar
Th 96-98 is different but the 99-01 itr is same as ctr cams. and the difference is very minimal
Old Jan 12, 2010 | 12:27 PM
dpetro1's Avatar
i run type-r springs/retainers with gsr cams rev limit is set at 8500 but i usually shift at 8k
made 400whp @ about 15psi on a 30r
Old Jan 12, 2010 | 12:58 PM
Turbo-LS's Avatar
Im currently running supertech springs/retainers with ctr cams reving to 9000. Really it all matters on the setup on how high you rev. You dont want to rev past where it stops makign power or where power levels off. if iots not producing then no reason to rev it
Old Jan 12, 2010 | 01:03 PM
sh!ft's Avatar
i got type r springs with supertec flat faced black nitrade coated std size valves
Old Jan 12, 2010 | 01:07 PM
boostedEF91's Avatar
usually the rev limit is set a couple rpm's after the car stops making power. but you have stock components.. i have full typeR head rev limit set at 8700.
Old Jan 12, 2010 | 01:18 PM
sh!ft's Avatar
so what cams should i use, the gsr's or the itr's or a combo setup?
Old Jan 12, 2010 | 01:25 PM
ITR cams are better then the gsr. IMO you should go with them. even a set of skunk2 tuner 1 cams. they are based of the ITR cams but with technology and testing add
Old Jan 12, 2010 | 01:36 PM
jdm inc's Avatar
I would go with the ITR's for your setup.
Old Jan 12, 2010 | 01:58 PM
sh!ft's Avatar
any suggestions on advancement of the cams? or is that a question the tuner should answer?
Old Jan 12, 2010 | 02:03 PM
tuner will deal with all that.
Old Jan 12, 2010 | 02:16 PM
jdm inc's Avatar
Tuner should deal with that, but usually they just leave em at zero on stock cams such as itr or ctrs
Old Jan 12, 2010 | 02:23 PM
Old Jan 12, 2010 | 03:00 PM
dpetro1's Avatar
agreed
Old Jan 12, 2010 | 03:46 PM
portenio78's Avatar
ITR's with a 30R and a little over 400whp here and love it!
92integraVTECgsr
Sep 26, 2010 05:02 AM
projectef
53
Sep 18, 2010 03:53 PM
Ls_eg6
Mar 6, 2009 06:32 PM
pHizerDC4
May 23, 2003 01:10 PM
sappsycho
Jul 31, 2002 09:16 PM
