B20Z Block issue (searched but nada!!!)
I just acquired a b20z block and ive got some internal parts that i wanted to load it up with piston, rods, bearings etc. but i got a little issue. I want to run boost but three of the head bolts in the block are stripped. Would the block still be able to be used if i get head studs and i take it to the machine shop to get it repaired for the three bolt that were stripped. Im currently running a sohc boosted but i would like to step up with a b-series....any help would be greatfull
Re: B20Z Block issue (searched but nada!!!)
yeah you need to get the threads repaired. my golden eagle sleeved b18 came from them with 3 stripped head stud holes so i got them time-serted and havent had a problem since. you should try to find a machine shop that does time serts they are way better than heli-coils. they make a specific time sert honda head stud repair kit but the Cadillac northstar kit works too and will probably be easier to find a shop that has the Cadillac kit.
HT White Ops
OP just ditch the block and find another one in good condition. Its not worth it to repair 3 bolt holes when you can just source another block. Its a stock junk b20 block, trash it. If you really wanted to the BEST fix for that would be to have the head tapped for 1/2 inch head studs.
OP if the block is in good shape otherwise get them time serted and you will be less into it then buying another block. just make sure the machine shop knows what they are doing.
That's the worst solution ever. Someone that converts to 1/2 inch head studs because of stripped issues, will be paying out their butt for as long as they own that block. It's very expensive to have custom gaskets (that don't leak) made.
Are you saying they sold you a core with 3 stripped bolt holes? If thats the case I would of told them to shove it..
had the same problem with my sleeved b18 got the time sert kit and been running for the last 2 years with no problems at all... here is the link for time sert http://www.timesert.com/html/mtrcsert.html
HT White Ops
The BEST, I didn't say most economical way to fix this is to have the block tapped for 1/2 headstuds.
HT White Ops
just to set things straight we did offer to fix the block even though we test them before they go out he opted to have a local shop timesert it instead. i don't know who told you putting 1/2 inch head studs in the block is the best way to fix it but they were wrong. if you use 1/2 inch head studs not only are the studs expensive but you now have to mod your head and every head gasket you use to match and that can be expensive as well. I'm yet to see a block that needed 1/2 inch head studs when i have seen 1500 hp on our standered head studs with no problems even with a timesert.
We did not ask him to pay shipping back and forth. We said if he would like to ship the block back we would repair it and ship it back free of charge. thats more then what most shops will do most will make you pay shipping both ways.
yeah well it should have been good when i got it $1020 for a block that i assembled and then would have to disasseble to ship back and then pay ship it back to you when it should have been right the first time you should have covered shipping both ways but i would rather pay to have it fixed intown same day so whatever its done and i am now happy with the block i understand you have policies and procedures that you have to follow and its over and done with and the block is holding up fine. at least you guys did offer to fix it, thanks for trying.
StolenTeg
05-31-2007 12:16 PM
V8 BAIT
07-01-2004 01:18 PM
