What is best setup for a b162
Old Jan 27, 2003 | 02:15 PM
00sitk's Avatar
Default What is best setup for a b16a2
I just want so input on what al of you have done/seen. i have 00 si that i drive like it is stolen and it keeps comeing back for more what is the best setup so that after uping the performance i can contine to rage this thing and not be looking a a rebuild every 6 months.
Thanks in advance
[Modified by 00sitk, 10:37 PM 1/27/2003]
Old Jan 27, 2003 | 02:43 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: What is best setup for a b162 (00sitk)
nothing If you drive it like it's stolen.
Old Jan 27, 2003 | 06:33 PM
00sitk's Avatar
Default Re: What is best setup for a b162 (HybridcivicLS-T)
come one guys i just want to know some of your thougths not about how i drive im trying to learn some **** and get some info from eveyone
How about some of your input good and bad about parts
Old Jan 27, 2003 | 06:34 PM
lazy bum shaughn's Avatar
Ok, I have a question. I hear that "drive it like you stole it" all the time, and I'm assuming they mean driving like a maniac.
I never stole in my life, but if I ever did, I woudn't be driving all crazy with a stolen car, I mean come on.
Old Jan 27, 2003 | 06:38 PM
Ek00fbp's Avatar
What are you asking? Engrish prease and what do you want from your car?
[Modified by Ek00si, 3:39 AM 1/28/2003]
LonelyDriver02's Avatar
Default Re: What is best setup for a b162 (lazy bum shaughn)
Thats true, i mean, if i stole a car, i'd probably be driving as least likely to get pulled over by a cop as possible, as to not draw attention to myself.
[Modified by LonelyDriver02, 9:39 PM 1/27/2003]
00sitk's Avatar
"drive it like i stole it" is my way of saying that im always in Vtec at 8000rpm's but that how you got to drive a b16 to get any kind of performance out of it.
im looking to have to perform the best it can and still be able to be a daily driver....(I will have to learn to control myself )
[Modified by 00sitk, 10:40 PM 1/27/2003]
Old Jan 27, 2003 | 06:39 PM
MotorMatrix.com's Avatar
I am a bad person
the question is kind of broad dont you think??? i mean are you planning to boost,SC or spray or go all motor?? we cant suggest a setup unless you list your budget,preference of FI or anything. how about some more info.
Old Jan 27, 2003 | 06:40 PM
Ek00fbp's Avatar
Default Re: What is best setup for a b162 (MotorMatrix.com)
If he wanted to go all motor why would he post in the forced induction forum
Old Jan 27, 2003 | 06:41 PM
00sitk's Avatar
Default Re: What is best setup for a b162 (Ek00si)
thankyou EK00si
Ok from my understanding right now turbo is the only way to go for highpower so what i guess i was asking is whats the best turbo setup , should i bore over the engine sleev or what .....what parts do you think are the best .....as for money ???????? i will soon be graduating from PSU with a ME degree so if i get a job the average is 60000 a year and i am willing to take time to save up and do everything all at once just trying to get a head start on everything and if i find out what is the best now by the time i go to buy it... it maybe cheaper ... but will probly just buy thigs as i find them............sorry for sounding like a dick.....
[Modified by 00sitk, 10:51 PM 1/27/2003]
Old Jan 27, 2003 | 06:44 PM
I am a bad person
thankyou EK00si
you still didnt post what your budget or plans are regardless. i listed all motor also since you never know how smart the noobs are around here. I was just trying to help but you obviously dont need it anyway.
Old Jan 27, 2003 | 07:57 PM
Ek00fbp's Avatar
It sounds like you want to go all out. YOu will want to re-sleeve the block golden eagle I hear is good and also Darton sleeves. Get some lower compression pistons JE 9:1 some rods crower, manley. They should balance your crank when you re-sleeve your motor. Build your bead by getting some ferria valves, titanium retainers, and titanium dual valve-springs. You will also need some high performance valve guides. You might want to port and polish the head while your at it. Get a new intake manifold, JG or sunk2, throttle body 65mm. That is for the build
as for the turbo you can either get a kit or just piece it together. You can get a drag kit with upgraded turbo to say a garret gt30 dual steel ballbearing. You will want to upgrade you wastegate from the delta that comes with it to a tial wastgate. Get a 2 1/2" downpipe if you want ac or 3" if u dont care. you will also need a good 3" exhaust all the way through. You will also need to get some injectors rc 440's or more depending on boost. Thats all I can think of right now. Later.
ps.s Arp head studs and main studs all new bearings etc. lets the pros worry about all that, new oil pump.
[Modified by Ek00si, 4:58 AM 1/28/2003]
Old Jan 27, 2003 | 08:16 PM
I am a bad person
Wow, where do you get the titanium valve springs??? anyway,rememeber to keep it simple. the more complex you make it the more problems you have. i made over 550whp with stock type r throttle body and intake manifold,no port no polish on type r head. standard ferrea stainless valves,springs and retainers. revhard log manifold and a simple hondata piggy back. the #1 thing you forgot amongst all of the high priced, high end parts ,is management. no matter what you build, no matter what quality parts you use if you dont have mgmt it will not last!!!
Old Jan 27, 2003 | 08:22 PM
00sitk's Avatar
Thanks for the input this is going to cost a few bucks ...... does anyone know of a got shop in PA maybe near pittsburge
Old Jan 27, 2003 | 09:53 PM
Ek00fbp's Avatar
okay the valve springs aren't titanium the retainers are the valve springs are mode of silicon yadi yadda metal. Ya i did forget management. There are alot of them out there but I am gonna get aem ems. Motec is just too much. Alot of people use hondata.
Old Jan 28, 2003 | 07:40 AM
yaya's Avatar
Default Re: What is best setup for a b16a2 (00sitk)
this is a good topic, i know there a lot of peeps with the same questions including me....im just curious on setups/parts and output
BUMP
Old Jan 29, 2003 | 12:20 PM
00sitk's Avatar
Default Re: What is best setup for a b16a2 (cancan)
i know more people than this have thoughts
Old Feb 23, 2003 | 04:45 PM
00sitk's Avatar
up
esohsee
Suspension & Brakes
19
Nov 20, 2006 02:13 PM
96turbohatch
Sep 23, 2004 02:42 PM
Jdm_Rice_Monster
Aug 17, 2004 09:34 PM
GS-R_nut
25
Oct 28, 2002 12:51 PM
Conechaser
Apr 24, 2002 05:43 AM
