WHAT THE????????
Old May 31, 2006 | 07:47 PM
blaxican05's Avatar
Default WHAT THE????????
ok so one side of my turbo (Pic A.) is all well and good with the vac line and oil feed and the return down at the bottom... but i turn the turbo over and see this hole (seen in Pic B.) What the hell is that for... i thought i had everything.... Please help!!!
Thanks in advance
Pic A.
Pic B.
Old May 31, 2006 | 07:49 PM
JDogg's Avatar
Default Re: WHAT THE???????? (blaxican05)
lol, its for coolant, same as the barb on the other side
Old May 31, 2006 | 07:50 PM
SOHCD16y8's Avatar
thats not a vacuum line on the one side. You have a water-cooled turbo and water lines need to be hooked up to the other sides.
Old May 31, 2006 | 07:51 PM
SOHCD16y8's Avatar
damn you owned me
Old May 31, 2006 | 07:52 PM
blaxican05's Avatar
Default Re: WHAT THE???????? (JDogg)
Water? where do i run the lines from
Old May 31, 2006 | 09:26 PM
PhantomX's Avatar
i would also like to know...
Old May 31, 2006 | 09:56 PM
ThePunk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaxican05 &raquo;</TD></TR><TR><TD CLASS="quote">
Water? where do i run the lines from</TD></TR></TABLE>
From next to the ice dispenser on your fridge...
Hint: Try engine coolant, like what runs through the radiator?
Old Jun 1, 2006 | 02:21 AM
Westrock2000's Avatar
Default Re: WHAT THE???????? (ThePunk)
Anywhere you can T in a small hose into the water supply...like off the throttle body.
Old Jun 1, 2006 | 04:16 AM
thermal's Avatar
Use the TB or IACV coolant lines. BTW, make sure that your feedline is not making a contact on your WG.
Old Jun 1, 2006 | 06:59 AM
drintegra's Avatar
there is a line that runs form the TB to the head tap that and you are done.
Old Jun 1, 2006 | 07:45 AM
racinskittle's Avatar
You dont necessarily NEED to run water lines. There's a few guys on here including myself that dont run water lines to the turbo (even though we have the passages on the turbo). It's not the best thing to do for the turbo, but you can leave it if you'd like. Up to you. Just make sure to let it cool down after running it hard otherwise it'll coke.
Emakulate
Aug 12, 2007 11:35 PM
sPaRk'iT
Oct 16, 2004 05:06 PM
ek_99_SiR
Aug 13, 2004 10:33 AM
Nameless RB26
Sep 24, 2003 08:06 PM
BlueShadow
Jan 23, 2003 05:58 AM
