what "sharp edges" on the piston are you supposed to sand down?
Re: what "sharp edges" on the piston are you supposed to sand down? (Short Round)
on that piston there really isnt any sharp edges. looks good to me , but what do i know .
I believe its the "sharp" edges that you seen arounfd the valve relief area...As far as grit/ wet sand, I think people have been doing this with scuff pads...You can use one of the rougher grits...Also try theoldone.com, they may have more info on this....HTH....
I used to do that with my 2strokes engine,
with 2000 wet sanding paper,
VERY LIGHT sanding around the piston top itself and a bit on the valves relief edge that's all sanding the pistons should not take more than 1 minute per piston. Be carefull not to touche the ring land and wash them perfect after you done this, wash with part's cleaner.
that's the way I did this on my dirt bike, but I never done it to 4 strokes engine.
I guess it's absolutly the same way caust it's the same metal for the piston and it's also the same purpose ( to reduce risk of detonation)
I Hope this help
Kranked.
I Hope this help
Kranked.
R-Poizon
Engine Machining & Assembly
04-27-2017 12:58 PM
bambam
30
01-18-2007 06:19 AM
