Went to the track:(
Old Jun 27, 2002 | 04:44 AM
TurbodCX's Avatar
Default Went to the track:(
r/t .611
60 2.202
330 6.19
1/8 9.36
mph 78.65
1000 11.97
1/4 14.17
mph 104.2
r/t .568
60 2.3
330 6.02
1/8 9.36
mph 79.95
1000 11.86
1/4 14.02
mph 106.84
r/t .616
60 2.30
330 6.15
1/8 9.29
mph 78.95
1000 11.96
1/4 14.13
mph 105.8
i dont understand this, i have good MPH but no E/T!!!!! last time i went to the track i was running 101-102 but i was netting 13.5-13.7 E/T
what could be wrong??
same track it was wbout 95 degrees out.
and i know my 60' sucks, because i was trying out some BFG drag radialS!!!(still learning how to lauch on these things)
i dont know
brian
[Modified by TurbodCX, 1:45 PM 6/27/2002]
Old Jun 27, 2002 | 05:58 AM
stick's Avatar
Default Re: Went to the track:( (TurbodCX)
yup ur trap speeds are on the mid 13 sec side but ur 60ft needs to be lower.
since ur in a hatch i would think ur times could be much lower once u work on ur launch and 60 ft.
keep practicing and dont get discouraged.
Old Jun 27, 2002 | 06:03 AM
VTC_CiViC's Avatar
Default Re: Went to the track:( (stick)
Actually, your traps are tickling high 12's for a CX (106mph). A 2.2 60', 104+mph trap and only 14.0-14.1.. something is wrong there, are you spinng down the track or something? My 1/4 mile times were 14.1 @ 100.7 with a 2.4 60' in a heavy *** EX coupe, worse 60' time but same 1/4 E/T/ with a slower trap.
Old Jun 27, 2002 | 06:19 AM
TurbodCX's Avatar
Default Re: Went to the track:( (VTC_CiViC)
it is not so much the spinning as i am bogging it coming out of the hole.
it usally goes good through first but then when i bust 2nd the car bogs, i think that i am shifting to early..
the car usally comes out real good and just starts to spin but stops and starts to pull, so i shift to 2nd early thinking that it is going to spin up on to the rev limiter, and i dont want that because that just slows me way down sitting the bounceing on the rev limiter.
brian
Old Jun 27, 2002 | 06:32 AM
sushibug's Avatar
keep trying and make us proud.
lets say the usual things you should already know... mash the gas then feather, double clutch and dont granny shift it... err, im bored. (was that even the slightest bit funny?) anyway man, keep practicing. every stop light is a potential chance to practice.
Old Jun 27, 2002 | 07:12 AM
TurboSedan's Avatar
New User
Sounds like you need to hold the revs up higher when you go to launch. With the Drag radials you can do that without too much wheelspin off the line. Try it out. You should have better times that way.
Old Jun 27, 2002 | 07:19 AM
shamoo's Avatar
Will you make something up for me please?
Try to launch higher (right under your peak torque) and slip the clutch real fast. Don't drop it. Once you modulate the clutch as you should, you should get a very good launch that way.
What rpm are you launching at?
Old Jun 27, 2002 | 07:20 AM
TurbodCX's Avatar
Default Re: Went to the track:( (shamoo)
i rev it to about 4500-5000 and dump it off, but the it boggs and **** like i said earlier.sooo slip it then??
brian
Old Jun 27, 2002 | 08:21 AM
DIRep972's Avatar
Smarter than you
ok. heres what i noticed about your times.
1/8 mph- 78-79
1/4 mph- 104-106
now that is a 26mph gain in the top end. It seems ur 1/8 mile goes really slow. and w/ ET's of 9.3 something is not going right after the luanch. maybe ur car just isnt making the power it should be in the low gears or maybe its something u an attribute to driving.
those tires will hook. HEAT THEM UP! white smoke the **** out of em and turn the wheels while u burn out to make sure u get all of the tire hot. u probably know to run around 15psi of pressure. do a 2nd gear burn out. I launch around 4500 and the car just hops off the line and hits boost right away. this is an LS turbo, u might be able to luanch even higher. 230/190 in a hatch, u could be pulling off high 12's @ 110 if u can improve what is going on in the 1/8 mile.
btw, my 1/8 mph is 83mph when I trap 104mph in the 1/4.
[Modified by DIRep972, 5:24 PM 6/27/2002]
Old Jun 27, 2002 | 08:53 AM
TurbodCX's Avatar
Default Re: Went to the track:( (DIRep972)
ok so i do, do a good burn out??
i was told not to do one with these tires??
they said just good *dry hop*
WTF
brian
Old Jun 27, 2002 | 09:05 AM
DIRep972's Avatar
Smarter than you
WTF
brian
who told u that?
just like slicks, u need to HEAT THEM BITCHES UP! nice and hot, they will hook like crazy.
Old Jun 27, 2002 | 09:11 AM
TurbodCX's Avatar
a hand full of crapmaro guys told me that.
so i bet that if i do a burn out it will do 1.8-1.9 60'
then i will go 13's oh yeah!!
thansk bro!!
Old Jun 27, 2002 | 09:34 AM
DIRep972's Avatar
Smarter than you
maybe 1.9's. 2.0's should come easy.
Old Jun 27, 2002 | 10:17 AM
newsense's Avatar
New User
If I could pull 1.9's on drag radials I could hit 12s. I need to get a set and try them out.
Old Jun 27, 2002 | 05:35 PM
SIK IN DA HED's Avatar
New User
Default Re: Went to the track:( (newsense)
dont forget to let some air out of those biotches.
Old Jun 28, 2002 | 05:08 AM
TurbodCX's Avatar
Default Re: Went to the track:( (dlplayboy)
yeah i was only runnig 12-15 psi of air in them at the time.
so i think i am good there!!!
brian
B18C1CYA
Jul 26, 2004 08:15 PM
B18C1CYA
Jul 26, 2004 03:26 PM
Adi Radoncic
Sep 1, 2002 11:37 PM
stevel
Jun 6, 2002 10:28 AM
mikeSONICGSR
Nov 5, 2001 07:02 PM
