smoking
Old Jun 25, 2002 | 04:41 PM
vtecsiqt's Avatar
Default smoking
I have a 94 Integra LS w/ drag kit, 160,000 mi, safc hack, 440s, 255 lph. Just today I noticed that smoke is pouring out from the breather filter. It smells clean, and I am wondering why this is happening, help! Also, I am blowing alot of what seems to be alot of blue smoke out the exhaust, especially when I hit full boost and shift it puffs a cloud the stays behind in the air. Put it this way, I have used about a full quart of oil in a week, granted I have done alot of full boost runs. I am assuming there is a large amount of blow by on the pistons. Anyone experience this especially the smoke coming out of the breather filter(scaring me)
Old Jun 25, 2002 | 04:42 PM
dustin's Avatar
Default Re: smoking (vtecsiqt)
Sounds like you have a lot of mileage on your motor -- oh wait, you do =P
time to rebuild
Old Jun 25, 2002 | 05:08 PM
vtecsiqt's Avatar
Default Re: smoking (dustin)
Thanks captain obvious, I am looking for a solution to the breather filter smoking mainly, not a wise *** remark. I Know I have to rebuild it, I am just running it till it blows up or till winter, The motor is cheap anyways!/ probably go with a b20 built, more torque baby!
Old Jun 25, 2002 | 05:13 PM
dustin's Avatar
You're welcome captain tact.
The solution is new rings and possibly pistons.
Old Jun 25, 2002 | 05:57 PM
Aeka GSR's Avatar
New User
Default Re: smoking
Old Jun 25, 2002 | 06:42 PM
PrecisionH23a's Avatar
Yep... that sounds like the solution to me. Your ringlands might have gone to hell, i recommend replacing everything asap before things get worse...
Old Jun 27, 2002 | 10:33 AM
WOTTEG's Avatar
I might suspect the valve seals.
Seems you are burning a LOT of oil, and because it is getting into the valve cover that makes me suspect the valve seals.
Good luck, and be careful.
Old Jun 27, 2002 | 11:42 AM
vtecsiqt's Avatar
how about i got 303 whp with it. huh! going to the track tomorrow
Old Jun 27, 2002 | 11:48 AM
JM Performance's Avatar
ok
Old Jun 27, 2002 | 11:51 AM
93LSivic's Avatar
Default Re: smoking (WOTTEG)
Doubt it. I was smoking pretty bad and figured I owuld replace the valve seals. Well, that wasnt the problem. I figure one of the oil rings took a ****. Rollerwaves are on the list to go in.
I would do a leakdown with the valvecover off to get a better idea of where the leakage is coming from. I heard mine coming from the oil return holes in the head, but still with good compression--so its definetly an oil ring.
Old Jun 27, 2002 | 02:15 PM
MiraiZ's Avatar
Default Re: smoking (93LSivic)
Roller waves ...that's where I'm going with mine too
Old Jun 28, 2002 | 05:58 AM
WOTTEG's Avatar
93LSivic: You have had the same problem that he is describing right? Did you have plumes of oil coming from your valve cover too? That's the only reason I suspect the seals. Or maybe an exhaust valve isn't sealing correctly when seated.
TURKISHFORCE
May 26, 2011 05:25 AM
sohczcturbo
Mar 10, 2007 10:13 AM
JSpecwest
Aug 10, 2001 08:37 AM
