Which welder for intercooler piping?
Old Feb 6, 2002 | 01:03 PM
boomslang's Avatar
Default Which welder for intercooler piping?
What kind of welder is good to weld thin walled steel piping? I have a little welding experience with a friend's TIG welder, but no other types. I know the welder I used was freaking $1500 or so. I don't want spend that kind of dough.
Are there other types of (cheaper) welders that would work? Keep in mind I am not making manifolds that need deep penetration, just I/C piping and maybe a downpipe.
Old Feb 6, 2002 | 03:37 PM
98hx99b18c's Avatar
Default Re: Which welder for intercooler piping? (Inlinefour)
Really depends on the material, for mild steel...you can use a MIG
With aluminum or SS you'll have to use the TIG, either way TIG is the better choice.
Old Feb 6, 2002 | 05:46 PM
Bnjmn's Avatar
TIG welders are quite expensive compared to MIGs and MIG welding if very easy. You can do steel, stainless, and aluminum (with a spool gun) with MIG.
Ben
Old Feb 6, 2002 | 05:49 PM
dustin's Avatar
Default Re: Which welder for intercooler piping? (Bnjmn)
TIG is what you want, MIG is probably what you'll get.
If you can afford it, you want this:
http://www.cyberweld.com/milmax140tig.html
Maxstar 140 TIG
Else, get this: http://www.cyberweld.com/millermatic135.html
Millermatic 135 MIG
I have this:
http://www.cyberweld.com/milmax200dx.html
Dustin
Old Feb 7, 2002 | 12:34 PM
boomslang's Avatar
Default Re: Which welder for intercooler piping? (dustin)
Thanks for the advice guys.
Old Feb 7, 2002 | 01:18 PM
dbman96's Avatar
New User
I can tell you from experience that MIG works on steel stuff but it is a bit of a pain in the *** to get a good penetration weld AND not blow holes through the pipe. I usually end up welding a bead around at low current to build up metal and then going over it again at higher current to get some penetration once there's enough material not to burn thru it. It is possible, results are decent, I haven't had a weld fail yet; it's just a bit ugly and a pain in the *** compared to TIG.
Old Feb 7, 2002 | 01:59 PM
paulzy's Avatar
Default Re: Which welder for intercooler piping? (dbman96)
do you guys get that cottage cheese look with the MIG wire feeders also?? I hate that...
Dustin: HOw's the econoTIG? DOes it come with everything needed? I don't know poo poo about TIg welders or TIG welding
Old Feb 7, 2002 | 02:32 PM
dbman96's Avatar
New User
Default Re: Which welder for intercooler piping? (Slow_ass_4dr)
Cottage cheese comes from welding with too little current in my experience; if you heat it up more it smooths out a lot... right before it blows a hole through your workpiece.
Old Feb 7, 2002 | 02:49 PM
rioninja's Avatar
You can get a nice 220v arc setup for a few hundred dollars. But, you wont be able to do aluminum, and arc welding is slightly harder to do than a feeder syle welder.
If i was welding intercooler piping, i would go for around 40amps with some thin rods. The best way to avoid blowing holes is to get rid of the gaps
gaps suck
Old Feb 7, 2002 | 04:05 PM
dustin's Avatar
Default Re: Which welder for intercooler piping? (RioNinja)
Stick welding is mad ugly.
The econotig is OK but it has a really low duty cycle and takes 68A input current.
You would be much, much better off getting the Maxstar 140. It's soo small and runs off normal house current.
Dustin
Old Feb 7, 2002 | 04:12 PM
paulzy's Avatar
basic maxstar 140 comes with everything I need right?
Old Feb 7, 2002 | 04:15 PM
dustin's Avatar
You want this one:
http://www.cyberweld.com/milmax140str.html
Comes w/ the remote that is very necessary.
Dustin
Old Feb 7, 2002 | 04:20 PM
BoostinDC2's Avatar
can you upgrade to a torch or does it only allow a stick welder
Old Feb 7, 2002 | 04:52 PM
boomslang's Avatar
Default Re: Which welder for intercooler piping? (BoostinDC2)
Stick welders weld pretty crappy from what I have seen.
Old Feb 7, 2002 | 05:11 PM
dustin's Avatar
The maxstar 140 is an awesome TIG welder that can also do stick (I dunno why you would ever want to though).
Dustin
Old Feb 7, 2002 | 05:39 PM
InfamousRS's Avatar
Im going to have my intercooler piping welded by a local welding shop when the time comes, but Im going to tac in place so all they have to do is weld the peices all the way around, not actually fit it to me car. Would I beable to use a basic MIG welder to tac stainless steel in place?
Old Feb 7, 2002 | 07:25 PM
Giuseppe's Avatar
gaps suck
ive got a cheapo arc welder, and as said it blows holes right through
gaps, how can i prevent this, id really like to weld my own piping...
JC whitney 2.5 U bends..
i already have the welder set at the lowest
amp setting that gives me enough current to spark my rods..
im using 3/16 (i think)
would thinner rods help.??
Old Feb 7, 2002 | 09:04 PM
rioninja's Avatar
Hey! whats with all the knocking stick welders? Dont get me wrong, i'm not recommending them to any newbie welders.
BUT, stick welders produce some of the BEST looking welds, not the crappiest. Its just a hell of a lot harder to weld with. I've been welding for years, and i'm just now starting to get good. Dont knock stick welders is all i'm saying, i'd put my best looking weld against a feeder weld anyday.
Old Feb 7, 2002 | 09:31 PM
paulzy's Avatar
let's forget about welding IC pipings....I think that's the easy part of the job...
What about trying to cut the pipes so that they match up nicely instead of leaving fawking 2" gap in between on some sides...I wanna know how everybody's piping looks so good compared to my artwork...
Old Feb 7, 2002 | 09:32 PM
dustin's Avatar
Old Feb 7, 2002 | 10:37 PM
TurboT's Avatar
i use a table saw with a metal cutting blade...
b16bri
Sep 30, 2010 08:59 AM
Gr8DC2R
Welding / Fabrication
Nov 11, 2007 06:45 PM
forcedaccord95
May 13, 2005 08:19 PM
adseguy
Oct 4, 2004 04:07 PM
Blown90hatcH
Oct 22, 2001 10:21 AM
