Weird Uberdata 1.7 datalogging issue
Old Oct 21, 2004 | 12:47 PM
Pfieff's Avatar
Default Weird Uberdata 1.7 datalogging issue
I'm using the nokia phone cable with uberdata 1.7 and my plx-m300 WB. The phone cable is in COM 1 and is running at 38400bps. When it tries to datalog, the numbers jump back and forth, one number being the correct reading and another being way off. For example, the rpms will read 850 then drop to 52 then back to 850 fairly quickly and continue to do this. Then when I go to the lambda log, it will fill in a couple boxes, but then it stops. Any ideas on what could be cuasing this?
Old Oct 21, 2004 | 12:54 PM
blundar's Avatar
yeah Uberdata 1.7's datalogging sucked ***. Grab the "unofficial" 1.70 release, it works much better.
Also check your J12... If you have J12 removed, some versions of the datalogging code get pissed off and don't work.
Old Oct 21, 2004 | 01:20 PM
Pfieff's Avatar
I think I have the unofficial 1.70 release, its not posted on the uberdata website, is it?
Old Oct 21, 2004 | 01:53 PM
Joseph Davis's Avatar
Default Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">Also check your J12... If you have J12 removed, some versions of the datalogging code get pissed off and don't work.</TD></TR></TABLE>
I haven't mucked with it, so maybe I shouldn't waste the bandwidth... Is Andy/B/wtfever planning on tweaking things so that datalogging code works with J12 removed, if it hasn't already been taken care of on 1.70?
Full duplex pls.
Old Oct 21, 2004 | 04:50 PM
Pfieff's Avatar
bump, any other ideas?
Old Oct 21, 2004 | 06:00 PM
UberTeg's Avatar
Default Re: (Pfieffdog)
peeps were bitching it didnt datalog fast enuf, so i sped it up and it got some desync errors, so i'm goign to slow it down again.
Old Oct 21, 2004 | 06:09 PM
Bailhatch's Avatar
Default Re: (UberTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UberTeg &raquo;</TD></TR><TR><TD CLASS="quote">peeps were bitching it didnt datalog fast enuf, so i sped it up and it got some desync errors, so i'm goign to slow it down again.</TD></TR></TABLE>
What exactly wasn't fast enough?
Old Oct 21, 2004 | 06:27 PM
UberTeg's Avatar
Default Re: (Bailhatch)
refresh rate on the sensors
Old Oct 21, 2004 | 07:03 PM
tubegown's Avatar
Uberdata isnt cool anymore since Uberfag is afro-less now.
Old Oct 21, 2004 | 10:40 PM
Default Re: (tubegown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tubegown &raquo;</TD></TR><TR><TD CLASS="quote">Uberdata isnt cool anymore since Uberfag is afro-less now.</TD></TR></TABLE>
Agreed. He never should have shaved his manbush.
Old Oct 22, 2004 | 12:43 PM
Pfieff's Avatar
ttt
zachvirus
Nov 27, 2007 12:37 AM
Mr. Giggles
Aug 11, 2006 05:21 AM
youngwon22
May 2, 2004 10:55 AM
speedracer33
28
Jul 23, 2003 06:28 PM
