Weird Misfiring? Problem
Old Oct 31, 2004 | 10:58 PM
  #26
SOHC_MShue's Avatar
Default Re: Weird Misfiring? Problem (SOHC_MShue)
http://www.ecimulti.org/uberda...=2054
heres a link to some of my logs now that i got the wideband. I'm still getting detonation on that tune ..even though its super rich. BTW that lean spike is when i let off the gas so don't mind that.
Old Nov 1, 2004 | 04:44 AM
  #27
SOHC_MShue's Avatar
bump
Old Nov 2, 2004 | 08:20 AM
  #28
SOHC_MShue's Avatar
can anyone help? I just tried using some 2 step colder plugs yesterday and they didn't work either. I took another two logs with them in and posted it up on that same link.
Old Nov 2, 2004 | 09:15 AM
  #29
adseguy's Avatar
I was just going to tell you that in my car running Uberdata and fuel pump/ etc. When I went to the boost tab I added 120% fuel and .8 timing. On my first time boosting I was in the low 13's for A/F. I added 3% to the entire boost portion of the table and then I was in the high 11's low 12's to fix the problem. So I was just going to tel you to just add a bunch of fuel and see if that was your problem. Glad you found your problem . Now get a compression tester and check your compression!
Old Nov 2, 2004 | 12:58 PM
  #30
SOHC_MShue's Avatar
Default Re: Weird Misfiring? Problem (adseguy)
well i still haven't found my problem. I datalogged some pulls on the maps i was detonating on and was still very rich..yet i was still detonating.
SOHC_MShue
Mar 1, 2005 05:42 AM
B18C1 Civic EG
11
Jan 15, 2005 12:41 PM
boosted lude
Dec 10, 2004 10:44 AM
Malgerus
Jul 31, 2002 02:04 PM
