Weird fuel problem with Hondata
Old Sep 14, 2003 | 06:50 PM
vtec.dc2's Avatar
Default Weird fuel problem with Hondata
O.k., this happend after i've installed 550's rc injectors, going from 370's
while cruising on the highway, i noticed my a/f gauge started to lean out little by little until it was completely on the lean side.. than somehow later it went back to normal..
tonight, again, i get this problem, i've had this ecu for over a year - never really had problems - what could be causing this? - can't be the injectors.. it has to be ecu right?
Old Sep 14, 2003 | 07:39 PM
vtec.dc2's Avatar
Default Re: Weird fuel problem with Hondata (vtec.dc2)
anyone?
Old Sep 15, 2003 | 10:59 AM
vtec.dc2's Avatar
help
Old Sep 15, 2003 | 12:13 PM
Andrea's Avatar
The problem is that your tune is sufficient enough for the entire low cam fuel map. What is happening is that you are traveling through different numerical fuel values, at different vacuum readings. You are going from a lean numerical value to a stoich numerical value. You should have the partial throttle maps tuned again with a wideband on the street.
Old Sep 15, 2003 | 12:47 PM
vtec.dc2's Avatar
Default Re: Weird fuel problem with Hondata (50trim EK)
if my car runs fine one minute and then this happens, it can't be related to tuning maps.. - these values can't be altered without the software and burner..
my car is street and dyno tuned.. this seems to be something malfunctioning.. its like everything shifted to the left, inluding boost.. when this happend, it wasn't just random.. it was from very start until i restarted car later and it wans't there..
Old Sep 15, 2003 | 03:55 PM
vtec.dc2's Avatar
bump the night
Old Sep 15, 2003 | 05:34 PM
markaria's Avatar
possibly a fuel pump/filter problem? Just a thought
Old Sep 15, 2003 | 05:40 PM
vtec.dc2's Avatar
Default Re: Weird fuel problem with Hondata (markaria)
i have about 8K on fuel filter, and soon to be 3k on fuel pump.. walbro fuel pump.. if its fuel pump.. what can i do to test it out?
Old Sep 15, 2003 | 07:37 PM
shermanyang's Avatar
Dude, i'm having the same problems...although i started with 550 injectors. i'm gonna see if it's my O2 sensor...even though i only have about 2k miles on my new O2!! maybe it may be my 3bar map?? ****...who the hell knows!! i'm gonna eventually take it back to my tuner and have him fix it. maybe my map??!!
Old Sep 16, 2003 | 08:26 PM
vtec.dc2's Avatar
anyone with 550's saturated injectors and having such problem?
Old Sep 30, 2003 | 06:45 PM
markaria's Avatar
have you found your problem yet?
Old Sep 30, 2003 | 06:57 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markaria &raquo;</TD></TR><TR><TD CLASS="quote">have you found your problem yet?</TD></TR></TABLE>
not yet.. will find out once i get my block built..
Old Sep 30, 2003 | 08:49 PM
i thought i had the problem fixed...but it happened again tonight. damn...i'm gonna try putting 10watt 10ohm resisitors on instead of using the resistor box and i'm also gonna check out my fuel pump tomorrow. i changed fuel filter, and fuel line and got it running a tad better...i also had a problem with my spark plug wires coming loose causing some kind of cut off...kinda like a revv limiter or boost cut. ordered some new plug wires too. damn gotta fix this problem...
PR8urVtec
Engine Management and Tuning
Oct 1, 2014 01:54 AM
FlewByU352
13
Aug 23, 2012 06:31 PM
supereg2
Mar 21, 2008 09:33 AM
racingfan
Jan 13, 2005 08:52 PM
whiteblurr
Jan 6, 2004 03:41 PM
