Weird aeromotive fpr problem.
Old May 13, 2008 | 09:27 PM
cbustuner's Avatar
Default Weird aeromotive fpr problem.
I am running a aeromotive 13301 universal bypass regulator
http://aeromotive.carshopinc.c...13301
I got that one because I didn't want to spend an extra 50 or so in ss lines and fittings and then need a 50-120 dollar aftermarket fuel rail.Anyways I bought a weapon R fuel pressure rail adapter and have a 5/16 line running from the rail to the inlet of the fpr and a 5/16 return.I also have a jegs gauge right off the fpr
Now here's the problem.When adjusting the regulator If I adjust it to raise the fuel pressure the motor will run like crap (Finish reading) but the afr's will go lean (at idle I'm at 13.4,with the fpr adjusted for more pressure I'm at 15-17.xx).You would think they would go richer right?When I lower the fuel pressure the afr's will go leaner.I had it as low as 20 psi and the afrs would be slightly lower then normal which does not seem right at all that an efi motor would run on 20 psi.Any sugestions? I'm thinking maybe my return or feed is too small?Gauge mounting location is bad?
Old May 14, 2008 | 11:54 AM
cbustuner's Avatar
Default Re: Weird aeromotive fpr problem. (cbustuner)
anyone?
Old May 14, 2008 | 04:24 PM
fastcody1's Avatar
is the gauge before or after the regulator
and are you taking the vacum line of the regulator when youre adjusting the regulator
Old May 14, 2008 | 04:42 PM
cbustuner's Avatar
Default Re: Weird aeromotive fpr problem. (fastcody1)
The gauge is mounted directly on the regulator,And I have been adjusting it with the line on.
boostedteg15
Jul 31, 2006 11:40 PM
6_GeArEd_TEG
Nov 27, 2004 09:57 PM
ATS*Mark
Jul 20, 2004 06:16 AM
BeeT
Jun 18, 2001 10:00 AM
