Ways to Up your boost...?
I have a custom built turbo application...but i was lookin for ways to up your boost besides a controller....i heard about just putting a heavier spring in your wastegate but i wasnt sure how this workd? Are there any other ways?
A) Build a manual boost controller from Home Depot parts (cheap)
B) Buy a WG spring that is designed for a higher boost level (~$45)
C) Buy a manual boost controller ($75+)
D) Buy an electronic boost controller ($200+)
Those are all the options that I can think of...
E) Insert a bleed orifice tee'd into the vacuum/boost line going to your wastegate.(cheap)
... and on a less contructive note...
F) Disconnect wastegate vacuum/boost line and control boost by feathering the throttle. (free)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">... and on a less contructive note...
F) Disconnect wastegate vacuum/boost line and control boost by feathering the throttle. (free)</TD></TR></TABLE>
lmfao. Thats a good idea, I am gonna have to try that
http://www.boostvalve.com/pricelist.html
cheap, but u can build it for cheaper if you get it just right
also get a bigger downpipe if u want faster boost, I dont recommend goin up in boost if you have a stock bottom end, just get a bigger downpipe and be happier with a faster spooling turbo and working motor
