Ways to make a Nitrous Kit Safer PLEASE HELP????????????
Old Mar 3, 2003 | 05:02 PM
integraautox's Avatar
Default Ways to make a Nitrous Kit Safer PLEASE HELP????????????
Ok I bought my zex kit for my integra ls I also purchased the gauge/manifold, EGt gauge and a/f gauge and bottle heater. I am going to replace the spark plugs. What other things can I do to make it run safetly. I have heard of an RPM set thing that wont let nitrous ingage with certain RPM's what is this and where can I buy it. Also I saw something that with deactivate the nitrous if you are running to lean or rich what is this and where can I buy it. Also what other tips and products do you guys recomend me getting. Thanks in advance.
Old Mar 3, 2003 | 05:06 PM
thrty8street's Avatar
Default Re: Ways to make a Nitrous Kit Safer PLEASE HELP???????????? (integraautox)
you would want to uprade your fuel system, which can include bigger injectors, a fuel rail and a fuel pressure regulator. you may also want to retard your timing about 1 or 2 degrees. simple bolt ons such as i/h/e also work hand in hand with nitrous.
Old Mar 3, 2003 | 06:09 PM
Default Re: Ways to make a Nitrous Kit Safer PLEASE HELP???????????? (thrty8street)
what are the rev controllers and the N20 cut off if it is running lean
Old Mar 3, 2003 | 07:07 PM
laughinxxx's Avatar
New User
1. Get your injectors cleaned
2. Fuel pump and FPR
3. Fuel pressure safety switch
4. MSD window switch
5. Go to dyno and check your AF
Old Mar 3, 2003 | 07:16 PM
Default Re: Ways to make a Nitrous Kit Safer PLEASE HELP???????????? (laughinxxx)
what is the fuel pressure safety switch?
Old Mar 4, 2003 | 05:50 AM
laughinxxx's Avatar
New User
It's a switch that kills power to your kit if fuel pressure drops below a certain PSI. I think they are a pain in the ***, but they work.
Edit: NOS makes one.
[Modified by laughinxxx, 6:51 AM 3/4/2003]
95greenlude
May 2, 2007 02:02 PM
JDMDC4life
Oct 12, 2006 02:18 PM
Azn Kenny
May 14, 2006 08:32 PM
YourHondaSucks
Feb 8, 2004 03:30 AM
Clean91B18A1
Jan 25, 2003 08:43 AM
