Watsegate Question
Old Jan 3, 2009 | 10:03 PM
garyherr's Avatar
Default Watsegate Question
It's a build 18c boosted project.Ok so I'm running out of funds. Heres my question.
I'm just planing on just boosting of the waste gate spring.I want atleast 14 lb so will I have to changed out the spring I have now because the box that it came in said 8.9 lb.
And at 14lb would I need a 3 bar map?My plane is just to run it like that as of now untill I have more funds. thanks
Old Jan 4, 2009 | 01:17 AM
grndcont's Avatar
Default Re: Watsegate Question
yes you would. what are you using to provide the extra fuel?
Old Jan 4, 2009 | 06:20 AM
supraccordlx's Avatar
11psi is the breaking point on the map sensor, you will have to upgrade if boosting more.
Old Jan 4, 2009 | 07:41 AM
90matthf's Avatar
You could just get one of the ball and spring regulators out of Mcmaster Carr and make your own boost controller and use the wasgate spring you have. That way you could get it up to the limits of the stock map sensor till you get a 3 bar, then turn it up.
2ndchirp
Jul 14, 2009 05:55 AM
stanzione88
Aug 19, 2008 08:46 AM
97grnrs
Jan 1, 2008 08:02 PM
ej1252
Nov 3, 2007 07:40 PM
fullboostin
Apr 2, 2004 10:28 AM
