watercooled turbo
Its been done, just use the search button. BUt I guess I will give you a tip, just make a loop with one of your TB or IM colant hooses. Not hard to do at all, takes about 5 minutes to do if that.
i have a D16Z6 with Y8 intake manifofld
i tapped the inlet for coolant to a TB line.. i Tee it to there
then the back of the block has a nipple by the water pump, i piut the return line there, so the vacumm of thepump will keep the coolant flow thru the turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">i have a D16Z6 with Y8 intake manifofld
then the back of the block has a nipple by the water pump, i piut the return line there, so the vacumm of thepump will keep the coolant flow thru the turbo</TD></TR></TABLE>
do you have a picture of your setup ?
can any body plesase post a pictures of the places i need to tAP INTO?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslowh23 »</TD></TR><TR><TD CLASS="quote">
if you need pic let me know</TD></TR></TABLE>
please if its not too complicated.
Civicman86
Jan 31, 2005 08:47 AM
