Water Wetter... Does it really work?
Old Oct 11, 2002 | 10:42 AM
MyWhiteCivic's Avatar
Default Water Wetter... Does it really work?
Like the title says. If it does work, does anyone know the actual temp. drop that it gave?
Old Oct 11, 2002 | 01:28 PM
boosted3g's Avatar
Default Re: Water Wetter... Does it really work? (MyWhiteCivic)
yeah it works. I noticed my temp gauge remained cooler but that is the extent of it. Ive used that and VP Cool Down, both work as they say
Old Oct 11, 2002 | 01:53 PM
Default Re: Water Wetter... Does it really work? (boosted3g)
Do you know how much it lowered the temp by?
Old Oct 11, 2002 | 02:03 PM
turbopanda's Avatar
I've used them. And I've used ordinary coolant. The difference is so minimal that I didn't even bother using water wetter or any other similar products, just didn't seem worth the money to me. I have a water temp gauge in my car, with sensor mounted at the top of the radiator, just before the piping that leads out of the radiator and into the engine, and I saw a 3°C difference. Do you think the extra money is really worth it? I don't. My car never overheats anyway because I have 4 fans on the radiator, and i've set a switch up so that they can be manually operated too
Old Oct 11, 2002 | 02:20 PM
mos's Avatar
mos
Default Re: Water Wetter... Does it really work? (turbopanda)
On my friend's car with a digital readout it made a 5 degree difference. I think its just soap with some anti-corrosive additives. Soap lowers water tension causing better heat transfer. It's mainly used by racers who are banned from using anti-freeze on track, but need an anti-corrosion additive to put into their distilled water. I've heard the type of soap used in industrial carpet cleaners might be the same.
Old Oct 11, 2002 | 02:37 PM
Def's Avatar
Def
Default Re: Water Wetter... Does it really work? (mos)
I doubt it is a soap, but it is a surfacant(soap acts as one as well).
It definitely works, but not some amazing amount. Just slightly increases the heat handling capacity of your radiator.
Old Oct 11, 2002 | 02:53 PM
rjardy's Avatar
Default Re: Water Wetter... Does it really work? (Def)
It has the same properties as soap.
Rob
hatchman88
May 30, 2009 05:50 PM
Driven
15
Jan 30, 2003 10:35 PM
turbohf
Jan 27, 2003 10:06 AM
Albino Dragon
Apr 18, 2002 10:15 PM
