water temp guage
Old Sep 20, 2007 | 10:42 PM
crxkid24's Avatar
Default water temp guage
so my crx is turbo and i been having problems with it running hot. i installed a autometer water temp guage. i used the sending unit that came with it. now my fan isnt working because obviously the old wire to the water temp sensor isnt plugged into anything anymore so its not telling the fan when to come on. so i tried to tap the old wire into the wire going to the sending unit but it causes the guage not to work. as soon as i unplug the old wire it works fine. anyone have any solutions to this? i dont want to hard wire the fan either. let me know what you guys think. thanks
Old Sep 21, 2007 | 07:51 AM
crxkid24's Avatar
no one?
Old Sep 21, 2007 | 08:16 AM
ham's Avatar
ham
Default Re: water temp guage (crxkid24)
youre supposed to use the sensor that comes with the gauge. you should leave the oem one alone and find another place to put the autometer one.
Old Sep 21, 2007 | 05:50 PM
crxkid24's Avatar
i did use the one that came with the gauge but i took the oem one out then put that one in. where should i put the autometer one then?
Old Sep 21, 2007 | 06:33 PM
OLD_HATCH's Avatar
Default Re: water temp guage (ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">youre supposed to use the sensor that comes with the gauge. you should leave the oem one alone and find another place to put the autometer one. </TD></TR></TABLE>
Old Sep 21, 2007 | 07:39 PM
mike93eh2's Avatar
Default Re: (crxkid24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxkid24 &raquo;</TD></TR><TR><TD CLASS="quote">i did use the one that came with the gauge but i took the oem one out then put that one in. where should i put the autometer one then?</TD></TR></TABLE>
i drilled and tapped the radiator hose water neck on the head and placed it there but you can also use one of these.
http://www.jazzproparts.com/pr...p.htm
teler86
Nov 1, 2006 03:14 PM
zccr-xsi
11
Feb 20, 2006 04:11 PM
VTECR021
Apr 22, 2004 08:04 PM
beaterdriver
Apr 15, 2004 08:05 AM
