Water injection or Nitrous?
Old Jun 16, 2003 | 06:14 AM
n1neb4ll's Avatar
Default Water injection or Nitrous?
Down here in texas it is starting to get pretty hot, and I would like to help my car live as long as it possibly can. I have been reading information about nitrous injection and water injection, but I wanted to know a little more about it that I couldn't find from reading.
1) is it possible to hurt your car from using nitrous injection due to the rush of hp, then turbo right after?
2) Which is more efficient at cooling the engine down
3) are there any other ways to cool the engine/turbo down that are more efficient?
thanks guys!!!
Old Jun 16, 2003 | 06:24 AM
GreddySi99's Avatar
Default Re: Water injection or Nitrous? (n1neb4ll)
use nitrous or methonal injection. water will only make you lose HP
Old Jun 16, 2003 | 07:03 AM
civic disobedience's Avatar
Default Re: Water injection or Nitrous? (intercooledJRSC)
here is a thread I created a while ago about intercooler spraying
this may help you...
https://honda-tech.com/zerothread?id=455912
Old Jun 16, 2003 | 07:09 AM
Dee's Avatar
Dee
Default Re: Water injection or Nitrous? (civic disobedience)
You will not lose hp when using water injection!!
Friend's SR20DET with aquamist. Stock bottomend and head with larger injectors, T04S, custom exhaust, TEC3.
http://images.andale.com/f2/10...0.jpg
Old Jun 16, 2003 | 07:20 AM
Default Re: Water injection or Nitrous? (Dee)
also check this out, it's an actice thread in the Drag forum about spraying water/bag-O-ice
https://honda-tech.com/zerothread?id=532948
Old Jun 16, 2003 | 07:50 AM
GreddySi99's Avatar
with all the variables the same being timing boost temp and whatnot you will lose power!!! Do yourself a favor put a stock car on the dyno. do a pull then put water injection on the same car without changing anything. It will lose power. Now if you change some things you can make more power but just soley buy installing it it will lose power
Old Jun 16, 2003 | 08:04 AM
PM-Performance's Avatar
from all the oldschoolers told me water/methanol combo works best.
i forget the parts, but supposedly the way to do i know a guy on stock block on his mr2 with like 180k on the clock on the thing and he does like 20psi on it becuase of the water/meth injection and he says the meth is dirt cheap too
Old Jun 16, 2003 | 11:21 AM
ion_four's Avatar
Yeah, water injection will make you lose power if you don't do anything else. The advantage is that you can run MORE boost with LESS fuel and MORE timing.
A turbo will also make you lose power, if you don't run any boost
blownLS
Aug 25, 2004 05:22 AM
benno
Oct 27, 2003 01:25 AM
madman13lm
Dec 5, 2002 04:40 AM
88CRXHybrid
Feb 6, 2002 08:49 PM
Accord94DX
Feb 1, 2002 12:13 AM
