Nitrous or water injection
Old Feb 6, 2002 | 08:20 PM
88CRXHybrid's Avatar
Default Nitrous or water injection
Which would be better to cool down intake charges and give a boost in hp? Can you run a small shot with Direct port nitrous? Or would a spearco water-injection 50%water/50% methenal be better?
Old Feb 6, 2002 | 08:37 PM
boosted hybrid's Avatar
Default Re: Nitrous or water injection (88CRXHybrid)
You cannot run nitrous all the time, therefore it isnt a good method for cooling down the intake air temp. Water injection is far superior and safer for cooling down your intake air temps. I use and run the spearco kit and love it. I have no knock at all at 10psi on my stock block LS. I also am using an intercooler...so water injection is a little overkill, but you can never be too safe.
Old Feb 6, 2002 | 08:41 PM
Default Re: Nitrous or water injection (boosted hybrid)
where did you put the fogger nozzel? As close to the throttle body as possible or more toward the intercooler?
Old Feb 6, 2002 | 08:45 PM
hybrid901's Avatar
Boostedhybrid how often do you add water? How are you controlling the h20 injecter?
Old Feb 6, 2002 | 08:47 PM
I put the nozzle that sprays the water after the BOV and before the throttle body. I control the water injection right now by the pressurized regulator that comes in the spearco kit. As soon as I get the tuning software for my PMS system i will let the unit control the spraying of the water through a solenoid at my specified rpm points, but that will all have to wait till i get back to the dyno.
Old Feb 6, 2002 | 08:49 PM
Oh i also use the 50/50 mixture of methahol and water. I refill the water resovior every tank of gas. I carry around a water 16oz water bottle to fill it...it is pre-mixed with the mixture so i dont have to worry about it when i am out.
elpiar
Apr 17, 2006 02:04 PM
mdixonjam
Apr 25, 2005 04:25 AM
blownLS
Aug 25, 2004 05:22 AM
n1neb4ll
Jun 16, 2003 11:21 AM
comptechgsr
Sep 20, 2002 11:51 AM
