wastgegate needs to go???
Old May 7, 2009 | 01:54 PM
boostfever's Avatar
Default wastgegate needs to go???
okay....when i turn my car on it seems to be okay but when i let the car warm up it will bog on me and it sounds like the engine is gonna die. took the wastegate hose off and the engine will sound smooth and will idle like a brand new car. once i but the hose back onto the wastegate it will bog on me and the engine will sound like it's gonna die again. this all happens while the engine is still on. anyone know what could be wrong? can it be the wastegate itself??
Old May 7, 2009 | 01:58 PM
miller's Avatar
Default Re: wastgegate needs to go???
It could be something along the lines of a tune issue. When you pull the line off the gate you are allowing more air into the engine as you are causing a vacuum leak.
Old May 7, 2009 | 02:00 PM
boostfever's Avatar
so just take the car back to get it tune? my wastegate seems to rattle when coming to a stop when in gear also.
Old May 7, 2009 | 03:30 PM
boostedcivicsir's Avatar
Mr. Badwrench
no miller is asking if it is running rich and maybe you have your boost reference coming from the manifold. and when you disconnect it, making a small vacuum leak, allows enough air in to overcome the running rich condition.
not saying go get it retuned. just trying to deduce whats wrong with the car.
Old May 8, 2009 | 07:07 PM
boostfever's Avatar
i think i have a boost leak which is making my car run super rich but don't really know why my wastegate would rattle when coming to a stop or idling down.
Old May 8, 2009 | 10:44 PM
DaveF's Avatar
a boost leak has nothing to do with the what the problem is, and apparently your problem is when your car is in vacuum.
Old May 9, 2009 | 06:55 AM
boostfever's Avatar
planning on getting new vacuum hose and getting new clamps and couplers and doing a boost leak test on it. hoping it's just a minor boost leak.
Old May 10, 2009 | 04:33 PM
DaveF's Avatar
that most likely wont fix it. your car has this issue for a reason. what the reason is, is a mystery without seeing the car 1st hand. we can only shoot in the dark with the posssibilities.
- map sensor not connected
- map sensor reading wrong
- fuel pressure way too high
- a comp table needs touching up.
and the list goes on....
Old May 11, 2009 | 06:50 AM
boostfever's Avatar
im not using the map sensor cause of my hondata s200 ecu
Old May 11, 2009 | 07:04 AM
00si2's Avatar
You still need a map sensor
Old May 12, 2009 | 12:15 PM
boostfever's Avatar
will the tuner at balanced performance in georgia who tune my car unplug my map sensor and told me that im not gonna be needing it. cars been running great with out it until i took my turbo and pipes off to recoat it.
boost gauge is reading 22 when in vac is it normal??
Old May 12, 2009 | 12:28 PM
redlinetuning's Avatar
Why did the tuner tell you that you don't need the map sensor?
Old May 12, 2009 | 12:54 PM
LSTEG96's Avatar
cause he didnt go to jordan. muahahahaha
jaredvabeach
Jan 11, 2010 09:56 AM
supabang
Aug 19, 2007 08:12 AM
swtch7
Jun 11, 2007 09:21 AM
99B16Si
Mar 4, 2006 07:45 PM
DubyaAye
Jul 11, 2004 08:21 PM
