wastgates?? pros and cons?
Old Sep 13, 2008 | 05:29 PM
Mad-Max18's Avatar
Default wastgates?? pros and cons?
Im getting ready to build my vtec b20 turbo and im going to use ether a gt28 or gt30 and should i buy with a internal wast gate or not ? what are the pros and cons of going with a internal wast gate and a external?
Old Sep 14, 2008 | 08:04 AM
TheShodan's Avatar
Moderator
It really is a matter of use, and how large the wastegate opening is, the size of the flapper door, and what the spring is rated. The only real cons is that if either of these are being pushed to their limits of use, you could experience boost creep, which could lead to a damaged engine. An external one can still cause that as well, but not as likely because the manifold should have it strategically placed where that shouldn't be an issue.
I guess it seems that your underlying question is "is it bad to use a GT28R or GT30R that has an internal gate?". The answer is no, if the amount of power and purpose are used correctly. I've had many GT30R internal gate setups that work just fine, but made sure that the wastegate was using a heavy duty spring, (about 14psi or so) and that the opening and flapper door were large enough. The ATP units can supply that.
Don't forget, that you will limit your choice of exhaust manifolds for the honda if you use an internal wastegate. There is really no cost savings in using an internal gate over an external one.
Old Sep 14, 2008 | 04:17 PM
Mad-Max18's Avatar
Default Re: (TheShodan)
thanks buddy
092eg6
May 12, 2010 06:38 PM
TnC
Oct 12, 2008 11:32 AM
radeon
Aug 16, 2005 10:42 PM
PM-Performance
Aug 6, 2004 06:39 PM
Spooled1.6L
Feb 21, 2004 08:23 AM
