Wastgate clearance?????
Old Oct 28, 2006 | 08:49 PM
dizzyek's Avatar
Default Wastgate clearance?????
Alrigh I'm in the process of installing my turbo kit.
When I was test fitting the manifold,dp,dt,turbo,wg the wastgate is almost hitting the exhaust turbine housing. I tried clocking the turbo but the clearence is the same all the way around.
You could fit one quarter between the wastegate and turbo housing thats it.
Is this going to be an issue, could the heat from the turbo housing mess up the wastegate?
What should I do.
BTW this is a peakboost manifold and tial wastegate.
Old Oct 29, 2006 | 01:25 AM
Schister66's Avatar
Man U FTW
do you have pics??
Old Oct 29, 2006 | 08:00 AM
dizzyek's Avatar
will have pics up shorley
Old Oct 30, 2006 | 10:53 PM
dizzyek's Avatar
I sit alright to shave a little of the turbo housing or a little off the wastgate???
Old Oct 30, 2006 | 10:56 PM
dunkd's Avatar
you shouldnt be having problems with a peakboost manifold. post pics.
Old Oct 31, 2006 | 04:34 PM
dizzyek's Avatar
I dont think it a big problem and I have heard this is a common issue with the peak boost manifolds.
Will post pics shorley
Dan_the_MaN
Oct 5, 2005 12:08 AM
redlseg
Jul 20, 2005 10:31 PM
NateTEG95
Sep 12, 2003 10:04 AM
XDEep
Mar 17, 2003 10:26 AM
