Wastegate vacuum hook up?
Old Sep 26, 2010 | 11:24 AM
tundra2000's Avatar
Default Wastegate vacuum hook up?
I got a nipple on the turbo piping right after the turbo and before the intercooler, should i hook the vacuum from the internal wastegate to a manual boost controller then to the nipple on the turbo piping? or do i hook it up to the intake manifold?
I'm wondering how to hook it up because i only have 2 vacuum ports on my b20 intake manifold one is for the blow off valve and the other is for the boost gauge which is T in with the fuel pressure regulator vacuum hose.
So how do i go about hooking it up?
Old Sep 26, 2010 | 02:49 PM
rndmheroxx's Avatar
Default Re: Wastegate vacuum hook up?
you got it right the first time. wastegate=>boost controller=>turbo nipple , good luck with everything!!!
Old Sep 27, 2010 | 07:05 AM
dpetro1's Avatar
x2 and to be clear nipple on the turbo piping is NOT vacuum. its a pressure source only.
Old Sep 28, 2010 | 02:01 PM
mechanix619's Avatar
I wouldn't "T" anything off the fuel pressure regulator. Personal preference.
Old Sep 28, 2010 | 03:58 PM
90turbointegra's Avatar
why do some people say put it on a vacuum source and some say on the turbo?
Does this really make a difference? And has anyone tried both locations and had different results?
Old Sep 28, 2010 | 05:23 PM
Hybrid96EK's Avatar
The directions from Tial specifically state to put the line on the bottom of the wastegate to a PRESSURE source, NOT a vacuum source. Does it make a difference in the performance of the wastegate? Im not 100% sure. Its been stated however that putting vac to the diaphram will eventually lead to failure.
Old Sep 28, 2010 | 05:24 PM
Mr. Chainsaw's Avatar
i personally like to put the boost reference AFTER the intercooler or even off the intake manifold. put it after the the intercooler because of the pressure drop, or on the intake manifold because...thats what your MAP is going to be reading.
2ndchirp
May 20, 2009 08:12 PM
jdm91CrxSi
24
Jun 27, 2006 02:21 PM
chriskey0829
Feb 1, 2006 07:10 PM
skierGT
Jun 21, 2004 09:32 AM
Ty.
Feb 3, 2004 04:15 AM
