which wastegate spring to use?
Old May 31, 2006 | 08:18 PM
mike93boost's Avatar
Default which wastegate spring to use?
which wastegate spring should i use on my 38mm tial at about 25-27psi??
Old May 31, 2006 | 08:55 PM
jep's Avatar
jep
what kind of ems and boost control are u running? do u want to set up gear based boost? for example if u run a 15 psi spring, then the least boost u will get in first gear is 15 psi so it really depends on your setup.
RCautoworks's Avatar
Default Re: which wastegate spring to use? (mike93boost)
Available spring pressure: .25Bar (3.63 psi), .4Bar (5.80 psi), .5Bar (7.25 psi), .6Bar (8.70 psi), .7Bar (10.15 psi), .8Bar (11.60psi), .9Bar (13.05 psi), 1.0Bar (14.50 psi)
High Pressure available: 1.1Bar (15.95 psi), 1.2Bar (17.40 psi), 1.3Bar (18.85 psi), 1.4Bar (20.30 psi), 1.5Bar (21.75 psi), 1.6Bar (23.20 psi)
Old May 31, 2006 | 09:04 PM
Default Re: (jep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jep &raquo;</TD></TR><TR><TD CLASS="quote">what kind of ems and boost control are u running? do u want to set up gear based boost? for example if u run a 15 psi spring, then the least boost u will get in first gear is 15 psi so it really depends on your setup.</TD></TR></TABLE>
probably hondata and a MBC maybe.
how do you setup gear based boost?
Old Jun 1, 2006 | 09:12 AM
Old Jun 1, 2006 | 09:34 AM
B18 CYA's Avatar
a big blue and a small blue will get u 23.2 psi, higher than that you will need a boost controller
Old Jun 1, 2006 | 11:07 AM
Soccerking3000's Avatar
Default Re: (mike93boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost &raquo;</TD></TR><TR><TD CLASS="quote">probably hondata and a MBC maybe.
how do you setup gear based boost?</TD></TR></TABLE>
gear based boost is available with the avc-r and worldsport controllers
Old Jun 4, 2006 | 04:45 PM
Default Re: (B18 CYA)
why do most people run like 20+psi and use like a 11psi spring or whatever??
Old Jun 4, 2006 | 04:49 PM
Adriano's Avatar
You shouldn't run more than double the spring rate. I would just get a 13-15lbs spring.
Adriano
Old Jun 4, 2006 | 04:53 PM
Default Re: (Adriano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano &raquo;</TD></TR><TR><TD CLASS="quote">You shouldn't run more than double the spring rate. I would just get a 13-15lbs spring.
Adriano</TD></TR></TABLE>
i see, why is that though? im use to internal gates..
Old Jun 4, 2006 | 05:05 PM
you can thats not right, many people run more than triple, it also allows you to more widely adjust boost
Old Jun 6, 2006 | 08:07 PM
so use a 0.9 bar spring and be done with it?
Old Jun 7, 2006 | 05:39 AM
yup
Old Jun 7, 2006 | 06:18 AM
nickromeo's Avatar
ive heard this before also!
but id like to know why this is true does it ruin the spring?
ie. making the spring see boost that it would normally never see?
nickromeo's Avatar
so is it best the set boost with springs then fine toon with an mbc?
Old Jun 7, 2006 | 06:26 AM
Default Re: which wastegate spring to use? (nickromeo)
well the 2 times the springs rate is false, it wont hurt the spring, i've ran 28psi on a 7.5 psi spring
Bobby_Budds
Engine Management and Tuning
Apr 28, 2012 02:21 PM
afrothunda713
Jul 10, 2006 09:40 AM
2LiterTurboSeR
Aug 25, 2005 11:04 PM
crxY-49
Jan 21, 2003 04:52 PM
zojirushi
Jan 23, 2002 04:42 PM
