wastegate missing a bolt will it hurt?
if your talking about that bolt/vacuum banjo fitting.. right dead center on top, its for a boost controller and you dont need anything to go in there, unless if you were to have a boost controller then you would use the fitting
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boro_DC2 »</TD></TR><TR><TD CLASS="quote">if your talking about that bolt/vacuum banjo fitting.. right dead center on top, its for a boost controller and you dont need anything to go in there, unless if you were to have a boost controller then you would use the fitting</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">yes that is for an electronic boost controller</TD></TR></TABLE>
its for any boost controller
1baddturbosi
Dec 10, 2006 08:12 AM
