Wastegate Help....
Old Jun 2, 2008 | 09:54 AM
kauai96's Avatar
Default Wastegate Help....
Ok this is my first step in to forced induction, and i was wondering about the wastegate, i have a generic ebay one im looking to replace in a little bit, but for now, i was wondering about running an open dump? what does it do? positives, negatives? do or dont?
Old Jun 2, 2008 | 10:06 AM
siblues's Avatar
Default Re: Wastegate Help.... (kauai96)
Open dump is pretty much just dumping exhaust fumes to atmosphere and a closed dump is exactly that it will remain closed and recirculate the fumes back into the exhaust.The only downfalls I can see is state emmisions might frown on an open dump tube and it has been said that an open dump will get a bit more power but I havent seen any charts to prove it?
Old Jun 2, 2008 | 10:23 AM
kauai96's Avatar
Default Re: Wastegate Help.... (siblues)
thanks, i dont really care baout the emission i was just wondering if it would cause damage or harm., now my next step is lookin for a replacement wasetgate, any body got any recomendations? budget build.
Old Jun 2, 2008 | 10:34 AM
inspyral's Avatar
Probably the most important thing about a dumptube(if it isn't recirculated into the downpipe/exhaust) is that it should be long enough to route gated exhaust gases well away from the intake side of the turbo. This means that extremely short dumptubes(or none at all) are a big no-no. As for a good budget wastegate, you can't go wrong with TiAL, and their 38mm gates are ~$200 new, and much less if you find a used one.
Old Jun 2, 2008 | 12:03 PM
siblues's Avatar
Default Re: (inspyral)
I am running a Tial on my setup and I am making what it says in my sig and its a 38mm so you dont need anything huge to make power and be able to control it.Tial is the way to go man or maybe turbosmart but I recommend Tial
Old Jun 2, 2008 | 12:39 PM
kauai96's Avatar
thanks again, so the tial? and about the dump tube, where did you route yours? or did u at all. oh yeh, will a shitty wastegate cause boost creep?
Old Jun 2, 2008 | 12:45 PM
GT35R_EF's Avatar
Make mine whatever you want
about the location of the dumptube dump location, just get it away from the intake side. A lot fo people route it in parallel with the downpipe, or just downward in a similar fashion. And to the question about the wastegate creep, the short answer is yes. But there are other things that could attribute to boost creep.
Cloneufc
May 13, 2009 05:57 PM
dezerte
Mar 8, 2007 06:57 AM
boondockgtr
Nov 13, 2003 10:00 AM
Integra808
Apr 3, 2003 06:08 PM
MyWhiteCivic
Sep 21, 2002 12:36 PM
