Wastegate flutter? compressor surge?
Old Dec 29, 2014 | 04:46 PM
rustproof's Avatar
Default Wastegate flutter? compressor surge?
hello
i have this problem on my car when i turn up the boost to about 19 psi. anything less then that it dosnt do that,
its a d16 with a 57trim .63 new tial external wg.
is the turbo to small?
Old Dec 29, 2014 | 05:50 PM
ek9_beast's Avatar
Default Re: Wastegate flutter? compressor surge?
Why are you posting an sti on honda-tech? Are u saying ur issue sounds exactly the same? The bottom video is the only one that works for me and is wastegate doin its job. Wasting boost. If you are getting a similar noise when u let off the gas its compressor surge and would do it because your bov isn't adjusted correctly. Wg spring size?
Old Dec 29, 2014 | 06:10 PM
wantboost's Avatar
Who is Mr Robot?
Is boost pressure stable through the rpm range? That should answer your question
Old Dec 30, 2014 | 04:00 PM
rustproof's Avatar
it is stable until i hit 18-19 psi.
thanks
Old Dec 30, 2014 | 11:00 PM
wantboost's Avatar
Who is Mr Robot?
And then what does it do
Old Dec 31, 2014 | 03:27 PM
rustproof's Avatar
boost goes up and down. like crazy.
geniuine tial bov
precision 38mm
any ideas?
Old Dec 31, 2014 | 05:37 PM
viper_boy403's Avatar
what spring is in the wastegate?
Old Jan 2, 2015 | 05:28 PM
tepid1's Avatar
Change the location of the supply line to the wastage. Should fix the issue.
Old Jan 3, 2015 | 10:16 PM
could be that he's turning the boost up too much past the base spring pressure
Old Jan 4, 2015 | 01:01 AM
wantboost's Avatar
Who is Mr Robot?
You're probably right. What's the base spring pressure
richboi
Apr 15, 2007 07:46 PM
SONIC BOOM
Oct 3, 2006 03:37 PM
b18cEF9
Jul 24, 2005 01:18 AM
beepy
Sep 13, 2004 10:12 PM
aracer69
Jul 8, 2003 07:01 AM
