wastegate actuator help needed
Old Oct 16, 2001 | 11:39 AM
jmad08's Avatar
New User
Default wastegate actuator help needed
i have a custom T25 on my EK and the wastegate is in the way of the fan. so far i made a notch in the fan housing so it fits perfectly but now when i spun the fan it clips the side of the actuator a little bit. is it bad if i trim all 4 fan blades just enough so it won't hit it or cutting the blades is bad overall? i still think even if i get a FAL it'll still be in the way of the wastegate actuator. a lot of people told me to cut the blades so it clears, i just want to get some more opinions and suggestions before i do cut it and this results in something bad. please help
Old Oct 16, 2001 | 11:43 AM
b18bturbo's Avatar
Default Re: wastegate actuator help needed (jmad08)
you can cut it but make sure you cut all equally. If not it wobble kinda funny.
Old Oct 16, 2001 | 07:31 PM
Incognito's Avatar
Default Re: wastegate actuator help needed (b18bturbo)
....or you can get one of those FAL slim fans.
Jeff, bring the car over. I'll look at it.
Old Oct 16, 2001 | 07:40 PM
dustin's Avatar
Default Re: wastegate actuator help needed (Incognito)
You can get much cheaper fans at pep boys that are just as effective.
I have the FAL fans and they cost me $275. I could have better used this money somewhere else.
Dustin
Old Oct 16, 2001 | 07:46 PM
LsTurbo91's Avatar
Default Re: wastegate actuator help needed (dustin)
I'll have to disagree here. I have those fans they suck. If its really hot like 90 degrees out, they have a hard time keeping up unless I leave them on running all the time. This has recently happened due to the fact that I put my ac back and the condensor is now blocking the radiator along with my intercooler.
Old Oct 16, 2001 | 07:48 PM
dustin's Avatar
Default Re: wastegate actuator help needed (9psiLsT)
Hmm all of the setups I saw with the pepboys fans had no issues. Maybe they were just lucky? I know my FAL fans are really really powerful... but it still seems like overkill with that steep of a price.
Dustin
Old Oct 16, 2001 | 07:52 PM
LsTurbo91's Avatar
I'll be glad to trade ya !! Its a 12" fan
Old Oct 16, 2001 | 07:53 PM
dustin's Avatar
Hehe, my FAL fans are worth 10 of your fans If you had 10 of your fans installed I bet you would have no cooling issues
Dustin
chieftaco
May 7, 2009 06:53 PM
Black Paper Diary
May 29, 2006 06:30 PM
B18bEK
Aug 8, 2004 10:54 PM
LS-T
Nov 20, 2002 11:06 AM
