waste gate question
Old Aug 9, 2004 | 01:53 PM
Trailz-EX's Avatar
Default waste gate question
im installing a turbo, all thats left is for me to get a waste gate. here is the question... are all wastegates where they bolt onto the header/manifold a universale size, or are there different sizes.. if so how do you figure out the size?? by measuring hole centers???
thanks
Old Aug 9, 2004 | 02:06 PM
RacerXI's Avatar
Default Re: waste gate question (Trailz-EX)
You'll have to use the wastegate that is flanged for your manifold. If your manifold doesn't already have a flange, that gives you more options (tial, hks, etc.). Soo, which manifold are ya using? btw, the tial 35/38 use the same flange.
Old Aug 9, 2004 | 02:33 PM
Trailz-EX's Avatar
Default Re: waste gate question (RacerXI)
i really dont know... it looks like someone built it in there basement.... (ebay buy)... at any rate heres a pic
if you cant see the pic, its cuz i dont know how to use computers.. if you can them thats sweet..
any rate the hole centers are 2 3/4 in. apart and the opening is 1 1/4in.
Old Aug 9, 2004 | 04:00 PM
Cramerox's Avatar
is the flange shaped like an sharp oval? if it is it im 99.99999 percent sure you can fit a tial 35mm on there. If its square then a tial 40mm
btw you have to host pictures, like imagestation.com...you can just copy the link from your comp.
Old Aug 9, 2004 | 05:09 PM
Trailz-EX's Avatar
Default Re: waste gate question (Cramerox)
Old Aug 9, 2004 | 05:24 PM
Bailhatch's Avatar
tial and turbosmart fit
Old Aug 9, 2004 | 05:33 PM
Trailz-EX's Avatar
Default Re: waste gate question (Bailhatch)
is there a specific size i need or just tial or turbosmart in general will fit? whats the 35mm mean or 38mm?? probably how big the opening for the exhaust to go through is huh? im only gonna run like 6.5 or 7 psi... what kind would you guys recommend?
Old Aug 9, 2004 | 05:43 PM
RacerXI's Avatar
You are correct on the tial 35/38 being the size. I'm not familiar w/ turbosmart Wg's. Just pick up a tial/turbosmart w/ the WG spring in what boost you want to run and go with it. Pick a lower spring if you plan on using a boost controller.
Old Aug 9, 2004 | 06:21 PM
Trailz-EX's Avatar
whats a decent price to pay for the tial?
Old Aug 9, 2004 | 06:33 PM
dennis's Avatar
can be had anywhere from $205 - $215 from vendors on HT - check venders marketplace. If you need feed/drain lines, can be had for $185 from fast-turbo.com (if stan's still offering the deal) - check his deal in above mentioned forum.
Old Aug 9, 2004 | 06:45 PM
Trailz-EX's Avatar
Default Re: waste gate question (dennis)
SI_frankenstein
Jul 16, 2011 03:45 PM
bunnyrabbit
Sep 14, 2005 09:39 AM
Acura_I-RS
Apr 18, 2005 09:23 AM
B00ST2nR
Jul 28, 2004 09:41 PM
evoeone
Mar 6, 2003 05:40 PM
