Waste Gate Flutter Help!!! ASAP
Old Oct 1, 2011 | 09:17 AM
BobbyRodriguez's Avatar
Default Waste Gate Flutter Help!!! ASAP
Can a waste gate be hooked up backwards and still work????
I need help. pls
Old Oct 1, 2011 | 03:22 PM
1KWHP1G's Avatar
Default Re: Waste Gate Flutter Help!!! ASAP
there are a few things that can malfunction on a wastegate. Is it an external or internal? What exactly is it doing? What do you have your boost gauge set to and what are you actually reaching?
Old Oct 1, 2011 | 06:06 PM
it open / closes at ideal.
I have the dump tube side connected to the manifold because of modifications, i know its backwards, but that's the only why it fits on my set-up.
then i have the top nipple to a vac block befor intake manifold.
and the bottom nipple to a charge pipe nipple right after turbo outlet.
any way i try it it opens/closes at ideal.
no vac lines , all vac lines, one vac line. anything, its a real tial and i opened it all is ok, but since it was backwards i lost the valve set on the real side driving on the high way.
Old Oct 1, 2011 | 06:07 PM
and will not hold boost at all, very little if any , but befor i had it hooked up to a log manifold backwards and it worked perfect. holding a 10-12psi
Old Oct 2, 2011 | 04:32 AM
bump
Old Oct 2, 2011 | 06:59 AM
EsotericImage's Avatar
Retired Moderator
umm yea, you cant mount backwards and expect it to work. the valve at the bottom is what opens and closes to release pressure.
Old Oct 2, 2011 | 09:12 AM
But cant the valve just stay close untill it hit spring pressure not matter what way its hooked up, as long as the vacuum lines are switched???? like a boost controller off the c/p and intake manifold pressure?
jetspeedz
Aug 23, 2009 02:21 PM
1fastlude1
May 2, 2008 01:40 PM
B16CRXT
Apr 24, 2005 07:50 PM
MooreBoost
Aug 13, 2004 05:54 PM
loke
Jun 7, 2004 02:13 PM
