Waste gate and bov hook up
i just bought a turbo kit for my civic and i was wondering where to hook the 2 vacuum lines for the waste gate and the line for the bov. Does it matter how far spaced apart they are? can I hook them into the same line...I only have one vac line ciming off the mani. Where do I hook the oil feed line up to and whats a good oil to use?
Hook the bov to the manifold and For the wastegate, I would tee it off the brake booster by itself, just so it has no problems reading vacuum. For the oil line i would recommend buying a sandwich plate. (cleaner and easier) like from here:
http://cgi.ebay.com/ebaymotors...ZWDVW
yes if you dont have a boost controller then the top stays open. The tfitting will work it goes between the oil pressure sensor is next to the oil filter and the back of the block. I never did it that why on my install only because I was worried that it would break off so i just got the sandwich plate......
90LSpimpin
Sep 10, 2005 04:47 AM
