BOV not actuating.
Old Mar 1, 2014 | 02:30 PM
mcdonoughEk00's Avatar
Default BOV not actuating.
Just picked up a hatchback that has a b20 turbo setup and the BOV isn't releasing boost pressure causing the turbo to.surge. I've replaced the vac line from the T to the BOV not sure what else I could try to fix the issue any input is appreciated
Old Mar 1, 2014 | 04:03 PM
ballistic1350's Avatar
Default Re: BOV not actuating.
Where do you have the pressure line plumbed in? mind posting up a picture?
Old Mar 2, 2014 | 07:04 AM
Fliiip's Avatar
No need to make 2 threads......
Take the bov off and make sure it isn't seized. Also, if it is adjustable, loosen it up.
Old Mar 2, 2014 | 12:29 PM
2 threads was an accident
Old Mar 2, 2014 | 12:31 PM
Pic
Old Mar 2, 2014 | 12:47 PM
wantboost's Avatar
Who is Mr Robot?
the tee is your issue, that small line can't supply enough vacuum to run the fpr, wastegate, and bov.
the wastegate needs it's own line, as does the blow off valve. the fpr has relatively low vacuum needs, the wastegate needs the strongest signal so it can operate correctly, same with the bov
Old Mar 3, 2014 | 03:43 AM
motoxxxman's Avatar
I don't see the bov line connected to the T, it looks to me like the bov line is connected directly to the intake mani. even if it was connected to the T, as long as there's no leaks it should still open perfectly fine. might hesitate a little, but would still open just fine.
my guess is a bad BOV, or a vacuum leak in the line.
P.S. you should never T anything into the line going to the FPR, it will cause inconsistent fuel pressures when manifold pressure is changing, which is basically all the time.
Old Mar 3, 2014 | 08:50 AM
E85B18's Avatar
This is probably your problem, the T does make a difference. Run a direct line and see if it fixes it. If not you may have a problem with the bov
racingchef
Jun 8, 2012 10:53 AM
spooned out
Jul 19, 2003 08:44 PM
len
Jun 4, 2003 05:32 PM
yisoulja
Mar 16, 2003 09:22 PM
