Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
bov and waste gate ?s
Old Feb 14, 2012 | 07:39 PM
autowrench07's Avatar
Default bov and waste gate ?s
ok so i just picked up this 98 civic. its got a b18b1 turboed. i plan on ripping it all out and redoing it all eventualy but for the time being i have a couple of questions. first the BOV has two vacuum ports in it. one in the top and one on the side twards the bottom but only one has a line running to it. the other one is just open. does anyone know about this. and 2 the wastegate has the same issue. there is twqo vacume lines on it but only one is hooked up? i did some research and found some diagrams of how it "should" be hooked up but i wana know if i change the way its set up could i potentialy **** it up? any help is great. and if your going to sit there and talk **** for what ever reason save your breath.
Old Feb 15, 2012 | 02:49 AM
mmcd's Avatar
Default Re: bov and waste gate ?s
The BOV should only have 1 one it, It sould run to the intake mani. And for the WG where dose the only line run to? It should have 2 lines? Do you have a BC or anykind or boost by gear?
Old Feb 15, 2012 | 02:53 AM
apexi_rsx's Avatar
usually thats how most people run those with just a vacuum line ran to the top nipple. the bottom one is for recirculating and venting air back into the system and most do not run it like that only on factory turbo vehicles.
Old Feb 15, 2012 | 04:18 AM
grumblemarc's Avatar
The Grumpiest
Leave it alone. Go to the Forced Induction forum and look at engine bay shots of other peoples builds if you're not sure what's routed to what.
Old Feb 15, 2012 | 04:55 AM
DELshaneSOL's Avatar
put the wastegate vacuum on the top one and let it blow up
v.i.gsr
Jul 13, 2011 04:09 PM
CustomX113
Sep 15, 2006 12:16 PM
LSEGHATCH
Oct 29, 2005 04:25 PM
patdemps
Jun 1, 2004 01:51 PM
01ITR#700
Nov 16, 2002 12:59 PM
