want a bit more power, what to do?
don't want to build motor.. what can i add to make a bit more power?
i was thinking gsr cams and exhaust cut out.. what else?
Re: want a bit more power, what to do? (r7)
If your sig is correct and your only running 7 psi then turn up the boost if you want more power. What are you running for fuel management?
forget more power, you need to get it to the ground or something.. a 13.4 at 107?? thats a good amount of power, you should be getting quicker e.t's.. good suspension and tires/slicks should help a lot...
Re: want a bit more power, what to do? (EG6chick)
yeah turn up the boost and maybe a 3 inch dp and exhaust, but a 2.2 60 ft I use to do that in my n/a b16 you must be spinning a lot get slicks and then dump it you should cut that 60 ft down to 1.9 maybe 1.8
Re: want a bit more power, what to do? (BoostedsiR)
thanks for the replys.. so
fix alignments, mainly camber
13", with 24.5" slicks
exaust cut out
sound good? =o
exaust cut out
sound good? =o
