walbro 255 quik question
Old May 24, 2005 | 05:36 PM
NewportSI's Avatar
Default walbro 255 quik question
I have my set up in, rc 440 drag kit, hondata, with a conservitive base 2lb boost cut till i get tuned june 24th, will i be ok putting the walbro pump in untuned ? need more info just ask
Old May 24, 2005 | 05:56 PM
NewportSI's Avatar
Default Re: walbro 255 quik question (NewportSI)
bump peter manfredo, I USED TO BOX IN THE SAME GYM yay for me
SOHCD16y8's Avatar
I dont see why not
Old May 24, 2005 | 06:57 PM
NewportSI's Avatar
Default Re: (SOHCD16y8)
anyone else have any more input on this ?
Old May 24, 2005 | 07:08 PM
s2kdre's Avatar
Default Re: (NewportSI)
you can put it in anytime, as soon as the rail fills up with fuel it dumps the rest in to the tank. So nothin is gonna happen
Old May 24, 2005 | 10:36 PM
turtle-eg's Avatar
Why not just use the fmu from the drag kit instead of the hondata until you bring it to a tuner? You will hit boost cut almost everytime you gas it pass 1/2 throttle.
Old May 25, 2005 | 04:24 AM
PrecisionH23a's Avatar
Some base maps are decent... some are absolutely horrible. I would wait untill it is tuned to drive around on the map. That's just me though.
Old May 25, 2005 | 07:08 AM
m R g S r's Avatar
If your asking just reqarding the fuel pump without boosting? Yes, it will be fine. I have had a walbro 255 in my car for two years. Once turbo, then back to NA, then nitrous, then turbo. It has worked fine with every single setup.
Old May 25, 2005 | 06:19 PM
NewportSI's Avatar
Default Re: walbro 255 quik question (m R g S r)
My hondata has a 2lb boost but in right now, so im not boosting even if i want to really, i just want to know if the walbro 255 fuel pump being in with my set up will **** anythign up or flood/run way tooo rich ?
Old May 25, 2005 | 06:35 PM
derrickracer2000's Avatar
it wont hert it for the safe side put a fuel reglator on ur car
97dc2
May 6, 2005 06:07 PM
sir00
Jan 29, 2005 11:23 PM
SweetChin
Mar 31, 2003 02:33 PM
flip1199
Aug 18, 2002 12:31 PM
pub
May 11, 2002 09:20 PM
