VTM wire for the V-AFC
Old Jul 1, 2002 | 11:59 AM
Evil EG's Avatar
Default VTM wire for the V-AFC
Since no one can help in the tech forum ill ask here.
I have a 00' GSR, ever since I installed my V-AFC every now and then I get a CEL. Mostly on highway pulls when I downshift to fourth then the light comes on and when the engine gets to 5000rpm's in stutters and I can't go any farther then 5000 after that. So I guess my question is do I need to hook up the VTM wire on a 00' GSR? Cause in the V-AFC manual it says I don't but in this little paper I got with the V-AFC it says I do, also on the trouble shooting on the Apexi website it says it needs to be hooked up also.
Thanks
_______
Old Jul 1, 2002 | 12:02 PM
CovertFI's Avatar
Default Re: VTM wire for the V-AFC (BVM)
if two places say you need to hook it up i would hook it up. what is a VTM?
Old Jul 1, 2002 | 12:18 PM
badCRX's Avatar
New User
Default Re: VTM wire for the V-AFC (CovertFI)
2 out of 3 sounds like a winner to me. It sounds like they originally thought that it wouldn't and then made a revision after the manuals were printed. That's the reason for the insert and the update on their website.
Old Jul 1, 2002 | 01:09 PM
M.A.R.C.'s Avatar
Default Re: VTM wire for the V-AFC (badCRX)
i think ya need it. I just put mine in with the VTM wire on. Works fine no CELs... although I DID cut the IACV wire instead of the MAP wire (i think it was map... whatever is blue/black on 99-00 obd2 harnesses). Try hooking it up... doesn't hurt to try. I think that wire is necessary for all VTEC motors
Old Jul 1, 2002 | 01:32 PM
98civicEX's Avatar
Default Re: VTM wire for the V-AFC (CivicRyda2k)
make sure you go to http://www.apexi.com on this and check, because there is a UPDATE about the VTM signal on there.
Old Jul 1, 2002 | 02:40 PM
rioninja's Avatar
Yes, definatly hook it up. The VTM signal is just the oil pressure sensor next to the vtec solenoid. without oil pressure at the solenoid, the computer wont engage vtec. Problem is, when the vafc is set to engage early it makes the pressure drop. So the computer wont even try to engage vtec on its own once it gets to the stock activation rpm (which also means no extra fuel, ignition, etc). What the vafc does, is fool the stock ecu into thinking that the oil pressure is always good.
Follow me?
Old Jul 1, 2002 | 09:00 PM
Evil EG's Avatar
Default Re: VTM wire for the V-AFC (RioNinja)
Thanks guys that seemed to be the problem. Just tested it with numerous highway pulls and no engine light or stutering.
a1320honda
Nov 13, 2005 01:10 PM
importdude2000
Dec 8, 2004 09:49 PM
darkstarsi
Oct 27, 2003 05:39 PM
SofaKing
Oct 2, 2003 11:32 PM
Evil EG
Jul 1, 2002 09:35 AM
