turbo vtec or else
Old Jul 20, 2002 | 10:29 PM
jonle28's Avatar
Default turbo vtec or else
i have heard different things from different people. The topic is, if i get a motor swap should i get a GSR and tubro it? or should i get an 18 from the LS and turbo that?? I have heard that the Vtec aren't good for a turbo motor. PLease help with any info, please. thanks
Old Jul 20, 2002 | 10:43 PM
Smashback's Avatar
Default Re: turbo vtec or else (DJSumYungGi)
Well stock vs. stock with the same setup the VTEC motor will put out more power. It's up to you to decide if the difference in power is worth spending that extra $2000 or so though.
Old Jul 21, 2002 | 06:35 PM
jonle28's Avatar
Default Re: turbo vtec or else (mplex2000)
i guess you don't understand. not the ******* engine
does a Vtec work GREAT with a turbo? or does the PSI cause the vtec to fail?
Old Jul 21, 2002 | 06:42 PM
MiraiZ's Avatar
Calm down dude....I think he answered your question!
Old Jul 21, 2002 | 06:50 PM
EpDarks's Avatar
Don't be a clown.
VTEC will work fine with boost, just gotta tune it right. The LS motor has lower compression, so technically, it should work better with a turbo. If you plan on leaving the internals stock, an LS motor is perfect. If you wanna get hardcore, build up the DOHC VTEC GS-R and tune it right, the B18C1 is for you.
xSOHC
May 24, 2012 06:49 AM
tegda
May 16, 2007 07:38 PM
dayaftertomorrow
May 2, 2005 01:41 PM
turbo89civicb18hatch
Jun 10, 2004 09:30 AM
Slvr_CRX
Aug 25, 2003 02:56 PM
