VTEC problem in boost
Old Dec 21, 2008 | 05:07 PM
  #26
JSPECSIR's Avatar
Default Re: VTEC problem in boost
does he have an oil pressure switch? if so check it. it should read as a closed circuit at lower rpms and an open circuit at higher rpms. if these fail to open the circuit and remove ground from its input on the ecu, vtec will disengage in 3rd and the cel will turn on. also connecting the vtec wire to the oil pressure switch wire as suggested earlier isnt the correct way to solve this issue and does not fool every ecu. if you are not running a pressure switch, then you can use a relay to connect a ground wire to the pressure switch wire then trigger the relay with the vtec wire to open the pressure switch circuit. or just turn it off in crome.
Old Dec 21, 2008 | 05:50 PM
  #27
turbo97coupe's Avatar
Old Dec 21, 2008 | 09:53 PM
  #28
rico892002's Avatar
yea my car have a vtec oil pressure switch. the the code is not a 22 which is vtec oil pressure switch. my code is 21 vtec solenoid
Old Dec 21, 2008 | 10:48 PM
  #29
yea i posted that in reply to boosted da . sorry bout that
Old Dec 22, 2008 | 05:59 PM
  #30
JSPECSIR's Avatar
ohm out the solenoid then. it should read between 14 and 25 ohms according to honda.
Old Dec 22, 2008 | 08:46 PM
  #31
ABK's Avatar
ABK
it's a better idea to take it off and send voltage to it, and ground the case. See if the pintle moves. Just because resistance checks out doesn't mean that it always works. Do it couple times see if it sticks.
juanq510
Dec 2, 2010 01:31 AM
DohctorVtec
Jan 16, 2007 05:43 AM
2k1 GSR
Mar 14, 2005 10:39 AM
papa_smurf
Jul 28, 2003 12:03 PM
UpstateCivic
May 10, 2003 05:18 PM
