Vtec with boost-- whats your setting?
Old Feb 8, 2004 | 04:00 PM
RedStarGsr's Avatar
Default Vtec with boost-- whats your setting?
Obviously after a dyno this would be much more easier to analyze, but on a small 60 trim t3...6psi... b17...stock cams, im trying to guestimate where i should set my vtec...
Im thinking 5700 (stock setting) b/c the car was set up like that stock to change there...but with the turbo Im not sure it should be lowered... currently its at 5100 but i cant tell if it dips after it, or before. im still getting used to the boost so i cant tell just yet. thanks for any advice you have to offer.
Old Feb 8, 2004 | 09:25 PM
RedStarGsr's Avatar
Default Re: Vtec with boost-- whats your setting? (RedStarGsr)
up for the nite.
Old Feb 8, 2004 | 09:35 PM
b16ahybrid's Avatar
it's hard to say where you need yours. Generally moving it up (lower rpm) will hurt performance. I moved mine to 6k rpm, because thats where it provided the least dip in power I only lost 2-3hp vs 15hp when it was set at 5,100 (give or take 100rpm, I cant remember)....
Old Feb 8, 2004 | 09:47 PM
Boofster's Avatar
Default Re: Vtec with boost-- whats your setting? (b16ahybrid)
You have to see where it creases the curve the least. Mine is at 5100. Up 100 or down 100 made a huge difference so you should easily be able to tell.
If your curve gets messed up, so will your top hp.
Old Feb 8, 2004 | 11:07 PM
RedStarGsr's Avatar
Default Re: Vtec with boost-- whats your setting? (Boofster)
im having traction problems...perhaps if i turn it up to 5700 or so maybe it will aid in that?
only way to truly tell is hop on a dyno im assuming? i have a wideband but im curiuos if theres any other way instead of looking at a dyno plot of tq vs whp...
Old Feb 9, 2004 | 10:46 AM
G
sh!t happens.
i have a boosted b17 to and my vtec is on stock at 5700. it does good for me. im on 6psi everyday driving and 10psi when i race. how you like the boost b17?
Old Feb 9, 2004 | 10:49 AM
PM-Performance's Avatar
Default Re: Vtec with boost-- whats your setting? (G"UNIT)
honestly the best way is to compate tqw curves from the dyno . any other way is really guessing other than trying to minimize the dip in a/f before vtec.
Old Feb 9, 2004 | 11:32 AM
RedStarGsr's Avatar
giggity giggity well alrite! whoa!
anyway, the boost is nice, i have a little oil leak from the SS oil return line to be fixed when some new fittings get here (id rather just wait to do it once and clean it up opposed to fixing it twice)
it pulls extremely hard at 4000 and doesn't stop...i love it. im really curious what my 1/4 mile is gonna be, but i shouldn't care, its just fun. i still need to echeck, then finish the exhaust..i may jump to a 3" b/c the funds would be there after selling my 60mm greddy, but i still need to tune and clean up some things. thanks for the advice guys...
BoostnEK6206
May 22, 2009 07:21 AM
99delsol
Oct 11, 2006 05:38 AM
Spooled1.6L
Sep 24, 2003 11:59 AM
sharkcohen
Jul 7, 2003 10:03 PM
extrmeboost
May 9, 2003 07:03 PM
