volvo turbo
Old Jan 2, 2007 | 10:36 PM
IP RACING's Avatar
Default volvo turbo
see them all the time at the junkyard wondering if they would be any good on a sohc zc.... just wanting some extra power... jUST A THOUGHT.. what do you guys think of them
Old Jan 2, 2007 | 10:58 PM
Schister66's Avatar
Man U FTW
personally i wouldnt do it, but if you're looking for a cheap setup, then i dont see why not...
Old Jan 2, 2007 | 11:32 PM
zexxbo's Avatar
Default Re: (Schister66)
a lot more people pick up the turbo's from mistubishi's because the flange and everything is a bit more conventional and there are kits to use mitsubishi turbos readily avail
Old Jan 3, 2007 | 03:34 AM
Bailhatch's Avatar
Default Re: (zeimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote">a lot more people pick up the turbo's from mistubishi's because the flange and everything is a bit more conventional and there are kits to use mitsubishi turbos readily avail</TD></TR></TABLE>
most older volvos use T3 turbos. it doesnt get any more conventional than that. They had turbos as big as a t3 50trims with .63 a/r turbines which is really fun on a single cam.
Old Jan 3, 2007 | 06:24 AM
IP RACING's Avatar
Default Re: (Bailhatch)
alright cool I think I might pick one up next time I go to the junkyard...I want to piece together a turbo set up for summer time.. I think it would be really fun! maybe only 6psi..sleeper too.... smic. black piping... that would be nice. any more opinions though....
Old Jan 3, 2007 | 10:46 AM
zexxbo's Avatar
Default Re: (IP RACING)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">most older volvos use T3 turbos. it doesnt get any more conventional than that. They had turbos as big as a t3 50trims with .63 a/r turbines which is really fun on a single cam. </TD></TR></TABLE>
true. but the keyword there is "older", which means youre probably going to have to rebuild it, in which case youre better off just buying a mitsu turbo or an aftermarket cheapie.
ive been down to the local pick-a-part and seen the volvo turbos but they either have a grip of shaftplay or the weird flange.
Old Jan 3, 2007 | 12:17 PM
IP RACING's Avatar
when I go to the local pikc your part.. man Ive found like 6 almost perfect no shaft play spins perfect.... they seem in reall good condition.. there a bitch to get off though....
how much boost can those handle
Old Jan 3, 2007 | 02:18 PM
Bailhatch's Avatar
Ya, back in the day I pulled and used about 10 volvo T3s on hondas. Found a few that had some play and just left them unless they had the .63 housing or some part i wanted...and one of the ones I installed burned oil. Other than that Ive had great luck with them
Old Jan 3, 2007 | 04:35 PM
IP RACING's Avatar
awesome... Ill keep a look out for stuff now... just start piecing that shi together for summer time
Whatever
Oct 16, 2008 10:08 AM
grandtheftlunchbox
Sep 17, 2008 06:06 AM
*Boostwerks*
May 28, 2006 08:27 PM
1990hondaHF
Apr 19, 2006 12:30 PM
stevelangford
Oct 1, 2004 07:05 AM
