D16z6...what turbo?
D16z6...what turbo?
I'd like to get a turbo that spools quick but also has power to redline....I read a lot about the t25/d16 combo, but some people say it stops making power after 5500+ RPM's while others still make power. I also read about t3's making lots of top end power but took a little longer to get going(again I focused on d16 fitment). ....My goal is 200"ish" HP....and the car would rarely get to the track to race....mostly in-town driving. Would a basic t25 or basic t3 be the best option? Thanks.
Re: D16z6...what turbo? (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">gt28r </TD></TR></TABLE>
Re: D16z6...what turbo? (1990hondaHF)
super 60 T3 or 28R should be perfect for you. Get a 28RS if you can afford it, or use a Mitsubishi 16g if you want a wonky inlet flange, but a cheap turbo.
for 200ish whp, a t3 42/48 will suit your needs. it'll pull to redline and spool up fast
or a t3 super 60 (it'll have a nicer top end).
most junkyard turbos (factory dsms and such) will achieve 200hp on a d16...
Re: (nerdsports)
I'm running a TD04 14G and I love it. Only Jesus blowing into the turbo could cause it to spool faster.
I managed a 13.7 w/ bad clutch and street tires.
For daily driving it kicks ***. Fast spool, it screams like a banshee, and the look on the faces of fat chicks in Monte Carlos as you blow by them is enough to make anyone smile.
Re: (nota-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">I'm running a TD04 14G and I love it.</TD></TR></TABLE>
How close to a t25 is the TD04?
Re: (1990hondaHF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hondaHF »</TD></TR><TR><TD CLASS="quote">How close to a t25 is the TD04?</TD></TR></TABLE>
I'm not really sure. It's bigger than a WRX turbo by a bit.
I'd say you can probably cover the compressor housing with your hand.
Re: (nerdsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports »</TD></TR><TR><TD CLASS="quote">for 200ish whp, a t3 42/48 will suit your needs. it'll pull to redline and spool up fast
most junkyard turbos (factory dsms and such) will achieve 200hp on a d16...</TD></TR></TABLE>
im going for the 14b...a lot of people make home made kits with it. same td04h turbo from mitsubishi's. thinking of what...250hp after i rebuild my motor? maybe running one bar will make 250hp on a d16z6.
Re: D16z6...what turbo? (rice a roni)
I'm going with a T3 .60 trim with .48 A/R turbine (.60/.48) on my y7/y8 mini me setup. They spool fairly quickly and will make power throughout the sohc redline.
