Vitara piston slap??
Old Jul 30, 2009 | 02:56 PM
hondahead''s Avatar
Default Vitara piston slap??
hey im having some kinda knocking issue with my turbo d16z6..motor is fully built with vitara pistons and FJD custom length I beam rods, also ACL race bearings and a goautoworks turbo kit. has about 500 miles on motor and makes sort of a knock noise when u let off the throttle,I hear its called a piston slap and is most common with the vitara set up,is this true should i not be concerned?I did compression test and its about 150-160 each cylinder so thats good.
what u guys think? thanks!
Old Jul 30, 2009 | 11:16 PM
da_dude's Avatar
Default Re: Vitara piston slap??
It's normal.
Old Jul 30, 2009 | 11:32 PM
92civicx's Avatar
Originally Posted by da_dude
It's normal.
very normal
Old Jul 31, 2009 | 10:41 AM
Boosted_B_Series's Avatar
I disagree.. From what I have seen it depends on the direction you point your arrows and pwc. We have built several that clack, several that are quite as a mouse.
Old Jul 31, 2009 | 10:45 AM
Op: Which direction did ou point your arrows, I hope you put the big valves in the big reliefs and disregard the arrows, esp with the equal length rods.
Your saying when you let off the gas you hear a knock? Any piston slap I have seen has been on cold starts.
Old Jul 31, 2009 | 10:53 AM
8VEYBEYB's Avatar
arrows towards flywheel = no slap / clack
arrows to timing belt =
Old Aug 2, 2009 | 07:50 AM
hondahead''s Avatar
yea thats what i mean, it suposed to go away after the car heats up but it dont.
Old Aug 2, 2009 | 08:58 AM
blackeg's Avatar
i guess thats why mine makes noise.
Old Aug 2, 2009 | 09:02 AM
riceburner700's Avatar
how is it at idle? is it making the noise
ham
33
Jan 26, 2011 11:07 AM
AK77
Dec 5, 2008 07:32 AM
pootie.teng
Mar 12, 2008 02:00 PM
Metal Head
Jun 9, 2006 08:12 AM
turboex
Jan 25, 2003 02:46 PM
