Vitara piston setup compression test....
Old Nov 13, 2005 | 04:01 PM
Widebody1's Avatar
Default Vitara piston setup compression test....
I did a compression test tonight for the hell of it and i got 120 across the board. Just thought id let people know and let others with vitaras post there numbers up. I have a d16y7. I think the numbers are a little lower than others because of the delta 272 cam and some material was removed from the combustion chamber. But it is a healthy motor with 1100 miles on it right now. Vitara people, post up your numbers.
Old Nov 13, 2005 | 04:05 PM
93turbo16's Avatar
I got a little under 140 with my setup. Y7/Y8 mini me.
Old Nov 16, 2005 | 08:59 AM
fjt's Avatar
fjt
150 psi on my Y7 right after installing them, stock cam...
after a year and 4 months i have
150
150
145
150
Old Nov 16, 2005 | 09:03 AM
splitime's Avatar
Default Re: (fjt)
155 across the board on my z6. That material removed from the combustion chamber will change it quite a bit.
Old Nov 16, 2005 | 09:29 AM
nonvtecD's Avatar
sounds about right, my y7 is 120-125 across the board.
aj345
Jun 2, 2013 07:58 PM
huntarrr
Nov 17, 2005 04:02 PM
@irborne
Nov 3, 2003 07:48 PM
performula
Oct 22, 2002 04:37 PM
